Question about Microwave Ovens
Amana Microwave I have a over the stove type Amana radar range. It started giving off a burning smell like electrical or something and now has quit heating entirely. It still runs just no heat. Any Ideas
  • Microwave Ovens Master
  • 9,086 Answers
I would suspect a shorted high voltage rectifier diode, a bad high voltage transformer, or a bad magnetron, in that order.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 16, 2008
Automatic burner lighter is not working on my gas range, Amana The Big Oven
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 26, 2011 | Amana Microwave Ovens
My Amana Radarange over the stove microwave started to omit a "burnt rubber" smell and stopped defrosting or heating anything all of a sudden. Model #MVH15W. Still works otherwise, lights on...
You're describing a common smell that goes along with a magnetron tube that has failed. The magnetron tube makes the microwaves, and will eventually fail if you keep a microwave long enough. They can fail in a couple of different ways, and one is to short out accompanied by that burning smell. It's probably not worth trying to repair your oven because of its age. I don't believe the magnetron is available any longer. If it is, it will be costly, and replacing the tube is best left to a professional because of safety concerns. Your most economical choice would be to replace the oven.
Feb 28, 2011 | Amana Microwave Ovens
WHEN START BUTTON PUSH THE MICROWAVE HAS A DEEP HUMM AND SMELLS LIKE SOMETHING ELECTRICAL BURNING. OTHERWISE SEEMS NORMAL BUT WON'T HEAT WELL. I QUIT USING IT. OPENED CASE AND DO NOT SEE BURNT COMPONETE.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 02, 2011 | Amana F1320 Microwave Oven
How to clean amana radar range?
This may not be for you your exact model, but all the use and care issues should apply to your microwave all the same.
Amana Use and Care Manual
Oct 21, 2010 | Amana Radarange Microwave Oven
I purchased a Samsung Over the Range microwave smells hot
are you using the rack inside all the time only use the rack when you have something on it. other than that contact 1-800-samsung
Mar 04, 2010 | Samsung Microwave Ovens
I have Amana Radar Range microwave. The repair guy was just here (fixing my real stove) and told me to change fuse to ''20 amp 250 volt fast acting ceramic fuse.'' Where is the fuse on this microwave?
first unplug your microwave and let sit for awhile to drain any stored energy that may zap you. then, if it is an "otr" there are 2 screws in the vent slats on top that you remove. once removed, you lift up on the control panel and it tilts out. voila! there is your fuse. pop it out and pop in a new one. ceramic 20 amp is correct. check your old fuse to be sure it is 20, not 15 though.
Aug 26, 2009 | Microwave Ovens
I have an Amana Microwave mvh250C, won't warm food
Absolutely not worth fixing as a brand new one with lots of features can now be purchased for as little as fifty dollars.
May 14, 2009 | Amana MVH250 Microwave Oven
Microwave oven replacement
Amana is under the Maytag umbrella.
Maytag customer service should be able to help but I think you may need to call instead of e-mailing.
Try them here: http://www.maytag.com/support/contact_us.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 27, 2008 | Microwave Ovens
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
