The Windows Genuine Advantage program for Windows XP uses Windows product activation, validation, and notifications to verify that your copy of Windows is genuine. Using genuine Windows delivers better performance and lets you access all downloads in the Microsoft Download Center, while helping to protect you from the risks of counterfeit software.
Activation is an anti-piracy technology designed to make sure that your copy of Windows XP is properly licensed. It works by verifying that the product key is valid and is only being used on the number of computers permitted by the software license. Activation uses a simple and fast process to protect your copy and ensure that you paid for the right thing.
Validation is a quick process that allows you to find out if the product key you activated is counterfeit or has been misused. For example, you may have accidentally received a product key that was reported as lost or stolen by its original owner. Sometimes, during a repair or reinstall, an invalid product key is used if the original product key is not handy. Microsoft values your privacy and does not use information collected during the validation process to identify you or contact you.1
Notifications helps Microsoft to fight software piracy and helps to you validate that the copy of Microsoft Windows XP that's installed on your computer is genuine and properly licensed. It reminds you that your copy of Windows XP did not pass validation and provides resources that help you to easily fix the problem online.
By confirming that your copy of Windows XP is genuine, you can take advantage of all the capabilities, support, and continuous improvements—as well as the peace of mind—that come with using genuine Windows.
If the above things wont done
Go thorugh this link
WGA Validation
Hope this will helps you
Thanks & Regards
Nanda Kishore.
Where did you buy your OS? maybe somebody else using your serial key or you have the same serial key on other PC.
it was already installed when i bought it...!!!how can i change serial key??
