Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Washer just shows the word pau and flashes the minutes, tried unplugging. for long periods just goes back to that.
  • 3 more comments
  • sbiickert Sep 21, 2008
    Mine is a ATF6000, but this morning it started doing the exact same thing.
  • arnoldromeyn Oct 02, 2008
    I get the pause light followed by err.....
  • olubie Nov 28, 2008
    I have the same problem, same model
  • tvtthan Dec 14, 2008
    i have the same problem. does anyone find out the solution?
  • hbenjaminsen Feb 17, 2009
    I am having this same problem. It started after my 2-year-old daughter hit a few buttons. I unplugged the unit for 30 minutes and it is still on pause. I need help!
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Posted on Sep 29, 2009
Frigidaire Affinity ATF7000E Front Load Washer locks the door then it doesn't start. What's wrong?
Good Afternoon Friend,
I understand the door locks on your Frigidaire Affinity washer, model# ATF7000E, and the load does not start. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
Code saids pau
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Code pau
For pause mode, just push the start/pause button again.
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
The front door will not lock and pau is flashing on my frigidaire affinity front end loading washing machine and it will not start
You will need to replace your door lock mech.
On the bottom of the door seal lift the edge and locate the retainer spring and remove the spring then remove the door boot,unscrew the door lock disconnect the wirng and replace the door lock mech
Oct 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
Won't start led read pau then 45
Hi!!
The error code 45 means control board communications problem. And Pau shows when the cycle was interrupted, try disconnecting the unit form the wall outlet, wait for about 10 secs. and plug it back in. If this do not clear the error code. Replace Board.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Frigidaire Affinity ATF7000E Front Load...
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
883 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
