Question about Consew 206RB
Consew 226 r sewing machine
I need to know how to put it back in time
like if it has timing marks ???
and where they are My Consew 205RB won't let the needle pick up the bobbin thread. The needle hits the bobbin occasionally and jams so tight that I have to use force to turn the machine wheel. When I try to sew, it lays the thread along the top of the material and causes a wadded mess of bobbin thread below. This is after I have loosened the set screws on the bottom shaft and moved it enough to free the jam.
  • Anonymous Mar 16, 2014
    I've tried several times to adjust the bobbin tension on the large screw, changed my needle, rethreaded the machine & still buckeling on the bottom of the fabric
  • Anonymous Mar 28, 2014
    case,has to be cut out, sews very little, loops
    on bottom thread seems tight,reverse makes it worse, I have changed both tentiions inmany posissions, nothing seems to work, changed needles,thread, is it worth having fixed? I have tried 3 times
    Genius:
  • 1,142 Answers
Do you have the user manual?
Posted on Sep 15, 2008
    Genius:
  • 1,847 Answers
Take the bobbin out and check for dirt or broken thread in the hole.
  • Legin Varghese
    Legin Varghese Sep 15, 2008
    You need to get the tensions right, Test the machines on
    their special thread, top tension about 5, you should be able to pull
    the bottom tension through with slight Resistance.
Manual
Apparently this is the same machine as the Consew 205RB-1, whose manual is available at http://www.consew.com/Files/112347/InstructionManuals/205RB-1.pdf
Jun 17, 2013 | Yamata Fy5318 Mechanical Sewing Machine
Yamata fy 5318 manual
I just received my FY5318. The manual has OK diagrams, but the text is Chinese. The Consew 205RB-1 is the same exact machine as the FY5318 and comes with the same manual but translated into English. It is downloadable from the Consew website.
http://www.consew.com/View/Consew-Model-205RB-1
Nov 17, 2011 | Sewing Machines
How can I download the manual for Consew - model# 206RB-1?
I changed the needle on my Comsew 205rb sewing machine and now it won't sew, it won't pick up the thread. Will it help to retime the machine and how do I do it?
Dec 20, 2010 | Consew 205RB-1
I have a stitching issue. I have a Consew 205rb and I just replaced the needle bar. I have everything setup to work and it grabs the bobbin thread everytime the needle goes down and comes back up but when...
Once you replace the needle bar you have to retime the machine, why did you have to replace the needle bar? email me with your make and I will attach timing instructions.
drivewithken@blueyonder.co.uk or you can keep adjusting the needle bar until the point of the hook is just above the eye of the needle.
Apr 10, 2010 | Consew 205RB-1
How do i set the timing on a consew 226
email me and I will attach instructions drivewithken@blueyonder.co.uk
Apr 06, 2010 | Consew 226R-1
I recently moved and can't find the belt to my Consew 226. Having problems finding a replacement. Can you help!
Go to www.consew.com and download the parts list for the 224 Consew. It's the same as the 226 for parts. Or, go to www.diamondneedle.com. They have nearly every part you're likely to need. I got bobbin case screws, a hook, some metal reusable bobbins, and some needles, all at very reasonable prices.
Oct 16, 2009 | Consew 226R-1
  • Take the side plate off and also take the needle plate off
  • Take the presser foot off, and put a new needle in the machine.
  • Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
  • Then, turn the handwheel toward you until the top line is where the bottom line was. Note: At this point, the tip of the hook should be directly in the scarf of the needle.
Jul 22, 2008 | Consew 206RB
Consew 206RB Logo
478 people viewed this question
Top Consew Sewing Machines Experts
River bottom
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
