Question about HP Computers & Internet
My HP printer is not printing even though I change the cartridge. Can you please help me solve the problem? thank you.
    Scholar:
  • 73 Answers
1)) Start - -> Run -- type services.msc...press OK
look 4 Print Spooler .....Restart the service
2))Restart the computer while the cable is unplugged....
Replug when the computer comes back
try It It Works...
Posted on Sep 15, 2008
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
My hp officejet 5610xi all in one showing cartridge error-refer to device documentation to troubleshoot.i changed an new cartridge still showing the same message.please help me to solve this problem.
If you are not using a HP print cartridge, try pulling out the one you put in, clean the contacts in the print carriage, and put in a different print cartridge - even if it is the same brand as the brand new one you just took out. I just solved the same problem with this method. I think the new black cartridge from Office Depot was defective. Once I cleaned the contacts on the machine and put in a new one, it worked!
Sep 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer not printing, message appears saying cartridges dont fit.
Have you recently changed your cartridges? Try replacing them, if you haven't printed for a while the cartridges will dry up and you will not be able to print.
May 31, 2010 | HP Officejet 5610 All-In-One InkJet...
The printer won't print. It says that the color cartridge needs to be replaced and even though I replaced it, it is showing 0%.
its a procedure to solve this problem first try this.
1) turn the printer ON.
2)then remove both colour and black cartridges out.
3)then take a moist tissue paper clean the brown dotted circuit on the cartridge and its base from where ink comes out for printing.
4)also where you install the cartridge in the printer there you will see the brown dotted circuit clean that also in printer section.then
5)directly remove the power wire from the back of the printer.
6)then remove the usb wire from the back of the printer(its the wire connection between pc and printer)
7)then wait for one minute then reconnect both the wires.
8)then turn the printer ON.
9) then insert the cartridges and check out,.
10) if same error shows up insert new black cartridge also.
this will solve the problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | HP OfficeJet d145 InkJet Printer
I have a hp office jet v 40 series fax, scanner, and copier
Get rid of the HP 45, it is not compatable, even though it looks the same. Go buy the HP15 and the problem will be solved.
Apr 14, 2009 | HP Office Equipment & Supplies
Multiple probs w/ HP 5150
Try `driverguide` on the net.
Update your printer driver, this should solve your problem.
Also check the printer lead is ok
Feb 02, 2009 | HP DeskJet 5150 InkJet Printer
Black light & print cartridge light is blinking. I changed the black cartridge but did not change the color cartridge cause I never use color. Both are in the printer. Black Light is blinking and...
Unfortuantely , to solve the issue , sadly, yes you will have to replace the empty cartridge to continue to use the printer in a normal fashion. Its a sneaky and dirty trick many printer manufactuers do to make more money off of the customer through the purchase of printer ink.
Aug 25, 2008 | HP Computers & Internet
Cartridge
whats your printer model?clean the catridge contacts and the print head insert it again properly then switch off and on,do a hard reset from the menu button ,and make sure your using a genuine catridge most especially if your printer is hp product.that should work
Aug 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
