You can use a universal hose for replacement. This hose should not be under high pressure (usually inlet water hose pressure). This is a bypass that is used when you release the trigger to wand. Look closely at the brass fittings of the hose, sometimes they can be reused by removing the clamp and cutting off the rubber part. Use automotive rubber hose (suitable for hot water system/radiator )or black pressure hose from Lowes (sold bulk) that will fit snugly on the barb and use simple clamps. You can make new hose by buying barbs and hose from Lowes or hardware/plumbing store. Good luck
