Copier Gestetner 3245 "LAN"
The LAN card of the afficio 450 and Gestetner 3245 is thesame...??
  • thraser
    thraser Sep 17, 2008
    tenkz a lot bubbabear64 ... il try it...
  • thraser
    do you have a (sp mode) program setting best foe gestetner 3245... im just using compatible toner...do u have ym?? can i chat u?? about how to troubleshot the copier machine...
  • 2,794 Answers
Yes they are.
Posted on Sep 15, 2008
I dont know my user code for gestetner 3245 aficio printer
Hello!
Try to call your IT. He can log in to the machine and look in the Address Book.
See you
Oct 08, 2011 | Ricoh Aficio 450 Copier
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Hw many grams dv is needed in afficio 450 or gestetner 3245
I just responded to your other thread, sounds like you are trying to use a generic dev, or something. You are asking for big trouble.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Copier.... afficio 450 vs konica 7025
You're talking about two really old machines, the 450 from 1998 & the 7025 from 2000.
Both are about the same class, but I'd give the edge to Ricoh since it was also sold under a number of other brands & replacement parts are readily available.
Hope this helps...
Sep 10, 2008 | Office Equipment & Supplies
Afficio 450 programs....
You have to have all the firmware in order to able to do that. It comes on a PCMCIA card that you plug into the copier. If you format the hard drive, there will be no way of getting the programs back unless you have that card.
There tough to get but I found a few of the cards on EBAY. Once you get that, then it's a matter of getting a hold of the software (if it isn't on the card already).
Aug 26, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Jul 20, 2008 | Ricoh Aficio 450 Copier
80 people viewed this question
k24674
