Question about Motorola Mobility RAZR V3
Motorola v3i invalide battery
Please send me this issue solve invalide battery in v3i
  • 2 more comments
  • millsy62 Nov 10, 2008
    I have the same invalid battery problem but please tell me how to reflash the firmware?
  • Marikpc Dec 27, 2008
    I have the same problem regarding invalid battery message and also getting a message that indicates unable to charge. The phone will only turn on if plug in to outlet. It will not turn on if plug in to PC USB. Any help will be greatly appreciated. Thank you in advance. Happy Holidays everyone!!
    Hugs,
    Mari
  • hdhatami Jan 09, 2009
    v3i invalid battry
  • jojobaboudou Feb 27, 2009
    pareille meme problème donc si kelkin a solution sa serai cool !!!
    Brigadier General:
  • 7,752 Answers
Reflash the firmware on your phone to correct the issue
Posted on Sep 21, 2008
Razr V3M and get invalid charger. I am using the same charger that came with the phone though it is a new battery.
The problem sounds like your phone problem. How old are both the phoen and charger. Who is your carrier. Depending on the carrier you may be able to get the phone replace. If you have are ready purchase a new battery and it is still saying invalid charger more and likely it is the phone. Clean the battery connections with a toothbrush. Also Use can air to blow out the dirt in the charging port. Clean these areas out very well and you should be find. If not contact motorola and have them send you a replacement. If your still getting a invaild charger. You may even be able to get them to send you a charger.
Oct 31, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Moto v3i invalid battery
there's a jumper solution to that problem. google..then type "v3i invalid sim" hardware solution. Then, follow the instructions. This method assumed you have soldering skills already. Hope this help.
Apr 06, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Invalid batery for v3i
your battery came of a non verizon phone verizon does this alot even with the charger they want you to buy from them only next time make shure its a verizon model battery good luck!
Sep 01, 2009 | Motorola Mobility New OEM RAZR V3 V3i...
Unlocking my motorola v3
you can try to quickly remove the battery power by tilting the battery so the phone momentarily looses power when it restarts that will usually bypass the lock code. if that will not work then you will need a data cable one from a digital camera will do and a program called rsd lite to get into the seem of the phone to retrieve the lock code that way. the software can be found with a google search.
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR v3i cellular
1-you have to configure your unit with your network provider.(GPRS/MMS setting).
2-maybe that certain files is not supported with your phone.
3-defective battery.
Mar 27, 2008 | Motorola Mobility RAZR V3i Cellular Phone
NTO ABLE TO CHARGE BATTERY
Try charging the battery for a long time.
Feb 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
MOTOROLA V3i MOBILE STOLEN
send and email with all detail to cop@vsnl.net they will tyr
Nov 28, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Mms in stead of sms
Clear inbox..sends MMS when SMS is full
Nov 06, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
322 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
