Question about LG 42PX4DR 42 in. Plasma TV
LG Plasma 42 inches RP-42PX11H
I bought this TV in Mexico (NTSC system), they told me it also worked for PAL. I moved to UAE (PAL System). I can see Cable , but no colors, just kiund of color stripes. Sound was OK. I have another LG 37 inches, and only can see black and white. Do you know why?
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
SOURCE: NTSC to PAL
I am afraid this reply is too late, but if you happen to stop by the site: The set has a built-in NTSC tuner, with no PAL tuner, as it is advertised in the US. So the answer is: No, you can't do PAL.
But if your manual says it has the PAL tuner, then you should be able to find a switch on the set or a button on the remote to change over to PAL.
Posted on Jul 24, 2008
SOURCE: I have a 42' LG plasma that has now has a 1 1/2
Own an DU42PX12XC that shows colorful vertical lines over half of the monitor, having only half visibility, sound is good.
Posted on Aug 30, 2009
phil_frye
  • 295 Answers
SOURCE: The screen on my 4 yr old 42 inch LG plasma keeps
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence.
Should be between $200 to $300 for a repair.
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
I bought a 42TA648BX philips and now I want to use it out of the country with PAL system - how can I do so?
You can't.You can't used NTSC tv frequencies on PAL system.U should of bought a tv call regions free tv than u can used is on NTSC or PAL frequencies systems.
Sep 16, 2011 | Philips 42TA648BX 42 in. LCD TV
Will a LG LED TV model 42LV3500 bought in Canada work in India
I'm sorry to inform you that the TV is not directly compatible with the power and color system available in India. The TV is only designed to work with 120V/60 Hz and NTSC color System. The power specification in India is 230V/50Hz. The color system is PAL.
However, you can use a Voltage converter and PAL to NTSC converter to make use of the TV in India.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 05, 2011 | LG 42 42LV3500 42 LCD TV
Sony bravia 40vl130 Serial No.8002109 made in Mexico during Aug 2007 bought from usa not working in dubai UAE what could be the reason ??? Can You please HELP ???
Hello
Bravia 40Vl series in not system compactable. The bravia you owns have only NTSC and ATSC system and is only meant for exclusive use in US. It can't be worked with PAL system in Dubai. So this set is worthless for you as you are in Dubai, India or any other part of the world where only PAL system is the standard for both transmission and recording. OK.
Apr 25, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I own a LG XCanvas PDP HDtv. I bought it in Korea and it's a Korean (power source) model. I want to ship it to America and use it there. Is this possible and safe for the t.v. and my home? Is it worth the...
Sell it before u leave Korea,tv from Asia used PAL signal frequencies.US tv used NTSC signal frequencies,not compatible.Tv PAL to NTSC signal frequencies,will not work.PAL and NTSC signal frequencies can't be mix.
Feb 02, 2011 | LG 42LC2D 42 in. LCD HDTV
Does PN50C550 unit work in PAL Syatem
Where did u bought this tv?Like in a European,Asia,Middle East or African countries.Yes tv should work with PAL systems or format.If it was bought in the US,Canda or Mexico probally not it only work with only NTSC systems or format only.
Feb 02, 2011 | Samsung PN50C550 50 in. TV
Does this model support PAL color system? I misplaced my user manual and i am unable to change settings.
Where did u bought this LCD tv,if u buy it in the US,Mexico or Canada no it only work with a NTSC signal frequencies.If buy in Europe,Asia,Australia,Middle East or Africa.Yes,it will work with PAL signal frequencies.
Dec 06, 2010 | Televison & Video
Please advise me what to do: recently I moved to Hungary with Sony TV Bravia KDL-40VL130 bought in the USA. I thought that this advanced TV would work anywhere in the world. However, it turned out it is...
Sorry u can't use this tv,because the US,Mexico and Canada tvs use a signal which run in call the NTSC signal frequencies.The European Union,Asia and the Middle East tvs use a signal which run in call the PAL signal frequencies.So,Pal or NTSC tvs signal frequencies can't not be mix.Can't modtifies these tvs it a PAL or a NTSC tvs and all it eclectronics circuitries run on that signal design frequencies.Those tvs,that call regions free tvs,Those tvs are design to run all over the world.Run on NTSC or PAL signals frequencies.
Oct 24, 2010 | Sony KDL32L4000 32 in. LCD HDTV
Can I use this TV in Argentina? where the transmission system is PAL-N vs. NTSC M of USA?
No,will not work,if PAL frequencies signal.NTSC frequencies signal only work in US,Mexico,and Canada.So,sorry no.
Sep 06, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
IS IT DELL 2606C TV LCD WORKING ON PAL SYSTEM?
U bought it in Euroupean,Asia countries?Yes,it will all those regions countries run on PAL frequincies.If u bought it in the US,Mexico and Canada.No the tv will not run on PAL or any PAL devices.The US,Mexico and Canada run on NTSC and NTSC devices only.
Jun 01, 2010 | Dell W2606C 26 in. HD-Ready LCD Television
DVD player only plays in black and white on Soniq 42'' Plasma TV. (Have tried 3 different players all have the same problem)
The color loss is most likely due to a NTSC/PAL compatibility issue. If you bought the players overseas in a PAL region (http://upload.wikimedia.org/wikipedia/commons/0/0d/PAL-NTSC-SECAM.svg) and the TV is NTSC or vice-versa, there will be a color loss. Thiss because the different regions have different formats and when you go from one to the other, the color does no transfer over. You can buy a PAL to NTSC or NTSC to PAL converter to fix this issue.
Oct 06, 2009 | Televison & Video
LG 42PX4DR 42 in. Plasma TV Logo
52 people viewed this question
Computer Repairing
Computer Repairing
