Question about Gateway MX6421 Notebook
Power problems recently the charger for my computer started to get really sensitive. i found that i have to hold the piece to the side when i plug it into the computer. is this just my charger or could it be a bigger problem with the actual plug in in the computer
  • 56 Answers
Does the chager cord look damaged in any way? If not then it is probably the plug in the computer.
Posted on Sep 15, 2008
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
3 year old pushed the z power key and computer went into shutdown mode. Now it has no power. I have unplugged it, and held down power key for 30 seconds as suggested by ACER but still no power
shouuld havee restartd when you hold the power button down release and push to start but try this remove the charger and battery from the laptop
then press and hold thee power button down for about 3seconds
replace the battery and charger(charger should be plug into power source)
push the power button to turn on should start up
May 30, 2011 | Acer Aspire m5640 PC Desktop
My battery died, tryed to charge and it wouldnt thought it was the charger so bought a new one and it still wont do anything. No charge no lights no boot
pull the battery out and unplug from power, Hold the power button down for 30 seconds (really hold it down for 30 seconds :-D ). Put the battery back in and reconnect charger.
May 03, 2011 | ASUS Eee PC 1000H Laptop
Charging Light is on when battery in , and charger plugged in , no reaction when power switch is pressed , fan not spinning ,no power light ,nothing . When battery take out , no charging light when charger...
This sounds like a USB problem. If there is a short or damage within the port the computor will detect it and prevent it from starting. Usually it's a USB port you always use. This may help, Plug in the mains charger and remove all USB devices. This will confirm weather its the computer or a USB cable/device. If the computer still doesn't start, get a bright light and a magnifying glass and look inside all the USB ports on the computer. In the middle of the port there is a flat plastic piece with 4 metal contacts attached to it. Check to see if they are bent, twisted or flattened in any way and with a pin or other suitable pointy device, attempt to straighten any damaged contacts. If you cannot get the contacts aligned, just try to get them away from each other and away from the wall of the port, then insert a piece of card or folded paper above and below the contact strip and tape them down. This will insulate the port and stop a reoccurance of the problem. You should find the computer starts (with a few complaints from windows) normally. this has worked for me 9 times out of 10 for this problem.
Good luck.
Apr 05, 2011 | Compaq Computers & Internet
My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
Apr 07, 2009 | T-Mobile MDA
HP Pavilion ZV5000 Charger
HP has a cord that plugs into the right side of the zv5000 that is intended for use with a docking station that they sell separately. The connector has a blade with a bunch of connections, but I only use 2, power and ground. The outermost contacts are power +and-. I bought the cord - re-wired my power cord to the new cord power wires - takes some figuring to determine correct wires - soldered them up and it has worked great for 2 years - much better connector also - squeeze side tabs to plug in or un-plug. This solution was about $25 if I remember - compared to $135 that the shop quoted me to replace the internal MB power connector
Oct 17, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Apr 09, 2008 | Computers & Internet
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Sharp SD-AT1000H
I am having the same problem...the manual says to un-plug the unit for five minutes and then plug it back in to re-set, but that is not working either...
Mar 23, 2008 | Sharp SD-AT1000H System
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
Gateway MX6421 Notebook Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
