My Optoma projector ep721 has tiny dots all over the screen. The lamp life exceeded sign came on so I replaced the bulb but the dots are still there. What do I do to make them go away?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at www.optoma.co.uk/support.aspx (UK) or http://www.optomausa.com/ (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
The ambient temperature in the room is to high. Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector to provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
1 of 2 things happened here. Either the power supply is spent or your lamp ballast is busted. In either case it would have to be opened and repaired professionally. may cost upwards of a new projector, so look around for a decent shop and have them test it. If you dont mind me asking, if you decide to get rid of it would you mind selling me the lamp cheaply. Doesnt matter if its burn out, just need the glass from the bulb if its not broken. Hope i helped.
