Question about Toshiba D-VR600
Error Message when dubbing
Message reads: "The TV System of the input video has changed." What does this mean? Suddenly I can't copy anything!!!
Thanks, Bob
  • 4 more comments
  • Anonymous Dec 03, 2008
    I have been trying to dub my home movies from VHS to DVD. Everything seems to be working well, when suddenly the unit stops recording and I get that same error message. I don't see or notice anything actually changing. What is changing? How do I stop it?
  • joannw922 Dec 06, 2008
    Same thing it will record for a few minutes, then kick off and I get the input message.
  • ripvw59 Dec 14, 2008
    When trying to dub from VCR to DVD the message "the tv system of input has changed" comes up and then dubbing stops.
  • blhans Feb 06, 2009
    Same message when I try to record off of TV. Playback is fine as well as VCR recording and playback.
  • griegert Feb 15, 2009
    Same problem and error code. If I input signal on Line 1 or Line 2 I get it. If I remove the video (yellow) cable it keeps recording the audio fine. I have tried 2 camcorders and several VCRs - most cause the problem but my Canon camcorder works fine? Something on the video out from the other devices. BTW, I am trying to record personal tapes, not copywrited.
  • ddhoffmann Mar 24, 2009
    I too have the same issue. Have know idea why but I've only used the device a few times. That would be about $100 a DVD :(
3 Suggested Answers
SOURCE: dubbing vhs to dvd
I have a toshiba dvd/vcr vr610 And I don't know how to dubb.I don't have the manual
Posted on Jan 16, 2010
djangelic
  • 18 Answers
SOURCE: Sony rdr-vx525 video cassette/dvd recorder.
Yeah, its a pain in the ****. The instructions to fix are here: http://angrytechblog.com/2011/02/how-to-one-touch-dub-vhs-to-dvd-on-the-sony-rdr-vx525/
Posted on Feb 08, 2011
If anyone can help me thank you forever. I have a PSP GO and suddenly appeared to me a message saying: can not read storage system please try to format storage from system settings. when I try to format I...
You need to call Sony. Since it is a PSP Go, chances are you are still under warranty. If you are not under warranty, they will usually fix it for cheap money.
Try this first: Go to Settings > System Settings > Restore Default Settings and then try to format it.
Jun 18, 2011 | Sony PlayStation Portable (PSP) Console
Samsung DVD Recorder "copy protected" error
I had a similar problem... went to samsung.com and downloaded firmware update for unit and instructions.... updated firmware and unit is now able to copy my own tapes from vhs to dvd.
Be sure to read and following firmware update instructions carefully...
Feb 24, 2010 | Samsung DVD-VR357
Dub a tape that is playing through my camcorder on TV
A vcr or dvd-recorder only reads the input signal. It does not care where it is coming from, only that it is there. You would have to run it through the vcr or dvdr for it to read the signal, or copy it to your computer and burn it to dvd.
May 27, 2009 | Sony Handycam DCR-IP7E Micro Digital...
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
No picture
Change the input on the TV to the input that you have the S or Composite (yellow) plugged into from the RCA
Channel 3 should be the cable or antenna input F connector.
Charles
Oct 30, 2008 | RCA RTDVD1 System
MacBook Error 36
Error 36 means “I/O error” (input/output error) and does not explain what the cause of the problem is, sorry.
Check your Mac for bad blocks you can use Disk Utility.
Aug 11, 2008 | Apple MacBook Mac Notebook
Copying vhs on to dvd
There are two methods for copying - one is called "one-touch dubbing" and the other is called the "GUI Method".
For one touch dubbing obviously you have the tape and disc both inserted and have the tape at the position you would like to start copying. Press and hold the Copying button in the direction of the media you're copying to (in this case, the arrow pointing to the DVD) for 3 seconds and it will either start copying or will prompt you on-screen of the television...
If you are using a disc that can be finalized (anything other than DVD+RW or DVD-RAM), you will get a message on the TV that says press Record to record and finalize or press Play to record without finalizing.
The GUI method is to press Functions - Copy, then select the copy direction and start copying.
Before finalizing a disc, when you go to play back the video it always starts with the last recording, not the first. This is probably why you think there is no movie there other than the 10 seconds of Arby's commercial (mmm, Arby's). However, this is the purpose of the Direct Navigator function. If you access it, you should see thumbnails of all of your recordings. Once you finalize the disc and playback, it should start from the beginning.
Mar 09, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Toshiba D-VR600 Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
