Question about Philips HTS-6500/37 System
The dreaded "no disc"
Same problem as many others. What can I do?
Read the other threads....
Posted on Oct 11, 2008
My sony has the dreaded green tint is that
As part of Sony's commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor) for optical block replacements on the models listed above until June 30th, 2009, regardless of purchase date. Authorized servicers should follow the normal process for warranty claims for this issue. This extended warranty does NOT apply to replaceable projection lamps or other parts that may be used in the televisions. All other terms of the Sony limited warranty continue to apply.
If the customer has general questions concerning the extended warranty have the customer contact Sony at 1-866-850-8674
Dec 24, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Xbox 360 dreaded Pink Screen...is it getting ready to die? TV is fine, movies are fine its just when games are being played. The screen is not solid pink, but the detailed aspects of the game are fuzzy...
I am afraid it might be going, I would try disconnecting the video cable and leaving it off for about a day. If that doesn't work, I would contact Xbox support, see what they say, and go from there.
Nov 06, 2009 | Microsoft Xbox 360 Console
Encoder disc replacement
The disk itself is just fastened with double sided tape to the gear. You only have to press it back onto the gear making sure that it passes between the opening in the u shaped sensor.
Jul 23, 2009 | HP DesignJet 130NR InkJet Printer
Disc stuck in the drive of my ps3,,,i've tried holding the eject button down, the paperclip trick..nothing worked...any other ideas??
no. just turn on the game n pick up the system.tilt it completely over 2 where the part where u insert thte disc is facing the ground.then,hold down the eject button.simple. no number.no repairing.
Jun 13, 2009 | Sony Playstation 3 (PS3) Console
Disc Read Error ( slim PS2)
Ah yes the dreaded DRE... time to replace your ps2 dude, this is the easiest and least headache solution.
Logged too many hours on those poor machines ;)
Aug 18, 2008 | Sony PlayStation 2 (PS2) Console
RE: Problem with SAMSUNG DVD-R135
If I understand correctly It would play DVD-R just fine & then it was no longer able to read them. If this is the case, are you using the same brand of DVD-R discs? Some read better than others Try using Imation they seem to read in alomost anything. If you still have problems I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. If it worked correctly in the first place I would assume a firmware update would not fix the problem. It is harder for the drive to read a burned disc than a pressed disc so that is why I recomend cleaning the lens. It has always worked for me.
If it still will not work then I would say that the laser pickup is failling, If thats the case in time it will no longer read retail DVD's
Feb 17, 2008 | Samsung DVD-R135
PS2 console
Hello , binksmom,
You are experiencing what I believe is the dreaded Disc Read Error. It means your laser lens is dirty. This can be solved by opening the Disc door and thoroughly cleaning the inside from hair, Dust, lent. Clean the laser with a q-tip lightly soaked with a cleaner like windex. Dry it thoroughly. Close it up and try it. Chance are you fixed it. if your problem is more severe, please check out www.playstationclinic.com
Regard and best wishes, Greg at the Playstation Clinic
Oct 14, 2007 | Sony PlayStation 2 (PS2) Console
Philips HTS-6500/37 System Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
