Question about Dishwashers
My viking dishwasher tilts forward when the door is opened causing the top rack to roll out by itself every time. Is this a problem with the legs or the screws into the side of the cabinet?
  • ph0enix Dec 14, 2008
    i have the same problem. No solution yet.
  • 2920 Answers
SOURCE: Dishwasher: upper tray rolls out everytime the door opens
put 2 small pieces of cardboard under the front legs until you get it where it wont roll out anymore. i had the came problem with my kenmore and it took care of it
Posted on Dec 28, 2008
watugot
  • 290 Answers
SOURCE: Bent leg
It's hard to say what to do about the leg without seeing it. You should at least try to get something under it to get it level as possible. If not perfect, it is better to have it tilted slightly back than foreward.
Posted on Oct 07, 2007
SOURCE: dishwasher tils when door is open because the bracket is roken
There is now a universal dishwasher bracket for just this problem called E-Z DISHWASHER BRACKET. It is available through Braxton-Bragg or ask for it at a local granite fabricator. It is very simple to use.
Posted on Oct 30, 2008
Kgt1962
  • 59 Answers
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Posted on Mar 11, 2009
  • 10 Answers
SOURCE: I noticed water coming from underneath my
Speak with who you purchased the dishwasher from. They will be able to point you in the direction to get a replacement and file a complaint. All of this is provided you bought the machine in the last year.
Posted on Mar 14, 2010
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
How do I level samsung dishwasher model DD6879000A after installed, presently at its lowest level and have a gap 2 in gap at the top. The top rack falls forward every time the door is opened.
Sounds like the back legs are fully adjusted.You should be able to adjust the front legs, the tool for this is usually supplied with the machine.
Mar 07, 2015 | Samsung Dishwashers
Top rack slides all the way out
Most likely your dishwasher is not level, but is tilting forward. Just extend the front leveling legs down further to raise the front end of the dishwasher. Otherwise, the rack glides may be damaged or bent.
Sep 18, 2014 | Dishwashers
Dishwasher slides when both top and bottom trays are out at the same time
Please clarify if the dishwasher is tilting forward when both the trays are out.
If so there are ways to install the machine so that it will not tilt. If your dishwasher is installed under the kitchen bench and there is a gap on top, the machine will tilt from the weight of dishes once the trays are rolled out.
The legs are adjustable, therefore, free the hoses and power cord. Pull the machine out so that you can untwist the legs to a height suitable to minimise the gap. Just leave enough space to allow you to push the machine back in with ease. You can always pack in cardboard or phoam later when machine is in.
If after legs are heightened and you still have a big gap, the you need to get to pieces of timber cut on either top edge to fill the gap.
There are specialty brackets (e.g. L-shaped brackets) which you can buy and screw into the cabinet walls to hold machine in.
Some machines have holes on the side or top to allow you to screw in from the wall of machine into the cabinet. However, I do not believe Electrolux models have this.
Let me know if I have misunderstood your problem.
Ash
Sep 19, 2011 | Electrolux Dishwashers
Upper basket keeps sliding forward as I load lower rack. Can you help me make an adjustment to prevent this annoyance. Thanks
Hello, Welcome to fixya. Based on the info you provided it's likely a pretty easy fix. The machine is leaning forward slightly and it shouldn't be. Remove the top screws fastening the machine to the counter...if applicable, some are on the side if granite counters or similar exist etc. Then take off the lower kickplate/access panel and screw the front leveling legs down ( which will cause the tilting of the machine back slightly ) and screw the back legs up, hence the rack should no longer slide out on it's own. macmarkus_77.jpg As shown above, these are locking nuts for the legs so make sure you loosen and re-tighten them in the process. Let me know how you make out. The most difficult part will likely be the removal and replacement of the toe panel/kickplate. It is possible the upper rack glides/ball holders have worn, this is usually identified by the customer finding gray pieces of plastic on the bottom of the tub, like this image shows below. i.e. macmarkus_78.jpg If this is indeed something you've noticed, follow this link to replace them. http://www.fixya.com/support/t6589773-replace_rail_replacements_in Thanks for choosing fixya and Good luck, Regards, Macmarkus :)
Nov 24, 2010 | Asko 1375 Dishwasher
Top drawer
Hello, Welcome to FixYa. Based on the info you provided it's likely a pretty easy fix. The machine is leaning forward slightly and it shouldn't be. Remove the top screws fastening the machine to the counter...if applicable, some are on the side if granite counters or similar exist etc. Then take off the lower kickplate/access panel and screw the front leveling legs down ( which will cause the tilting of the machine back slightly ) and screw the back legs up, hence the rack should no longer slide out on it's own. There are also locking nuts for the legs so make sure you loosen amd re-tighten them in the process. Let me know how you make out. The most difficult part will likely be the removal and replacement of the toe panel/kickplate. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1706 Built-in Dishwasher
Cant open dishwasher doorany hints?
In order to release the latch mechanism you need to either get inside the door or you need to get to the top of the cabinet of the dishwasher. The screws that hold your dishwasher into the cabinet are up under the lip of the cabinet. The door may be in the way of getting a screwdriver in to get the screws out so that you could slide the dishwasher forward to see the latch on top of the case of the dishwasher. You might be able to get a right angel screwdriver into the space between the door and the cabinet and work those screws out. You may have to remove the bottom panel on the dishwasher and screw the legs up a bit in order to pull the dishwasher forward. If you get the dishwasher forward, you may have to disassemble the latch mechanism enough to get the door open. Then comes the problem of figuring out what caused the latch to stick. I hope this will help you resolve your immediate problem
May 12, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Dec 28, 2008 | Viking DFUD142 Built-in Dishwasher
Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
248 people viewed this question
Top Dishwashers Experts
