Question about HP OfficeJet 7410 All-In-One InkJet Printer
Hp 7410 officejet all in one
Message reads to close cover - when cover is closed - will not scan copy or fax at all
    Sergeant:
  • 399 Answers
--close cover ---means the lower base of the printer is open the cover you open when to remove or insert the cartridges.that is not related to copy or scan cover which is above that.just close the lower covwer little bit tightly.apply gentle force or push to make it close properly.
do it carefully.
thanks.
Posted on Sep 18, 2008
Hp officejet 7410 will not fax or scan
Needs little bit technical skill level to do this activity:Open adf unit, remove flat bed glass, take out CCD unit, open bonnet of CCD, clean reflcted gasses with smooth cotton cloth or ear buds(no solvents requited) fix it back, clean glass both side, fix back all, try it..best of luck..Pl see the snaps for help:
Feb 04, 2012 | HP OfficeJet Office Equipment & Supplies
My HP Officejet 6310xi displays a vertical line when copies are fed through the ADF and when sending faxes through the ADF, the same problem occurs. What could be the cause?
Open the Top Feeder Cover
Clean the Roller with lint free cloth.
Lift the Roller a bit up and you will find a glass strip underneath the rollers
Clean the glass strip with cloth and close the feeder
Try scanning or copying. it should work
Regards,
Ron
Mar 04, 2011 | HP Officejet 6310 All-In-One InkJet...
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
LOST SCAN CD FOR HP OFFICEJET 7410
Try downloading the latest drives from HP:
http://www.hp.com/#Support
Follow the prompts and be ready to enter the model number of your OfficeJet.
You will be presented with various options/donloads.  Grab the appropriate one for the operating system you are running.
Feb 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanning from HP OfficeJet 7410 All-In-One to a Mac
Had same problem. Make sure you've closed any other apps. Itunes caused mine to fall over.
Jan 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Blue line vertical on all color copy and scans...help
try this web page, copy and paste the link into address bar. search facilty at top
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+7410+All-in-One&pid=391195&productBigSeriesOid=391192&spid=391194&opname=HP+Officejet+7410+All-in-One&contextual_lname=&pname_desc=HP+Officejet+7410+All-in-One+Printer%2FFax%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Officejet+7410+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=-1&method=prodFinder&qry=blue+vertical+line&Submit.x=0&Submit.y=0&Submit=go
Nov 01, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
76 people viewed this question
Seeker5211
Seeker5211
