Question about Dell 1710 Laser Printer
Dell 1710 jam
I am getting the jam with about 2 inches of paper sticking out past the back rollers. From your previous post, it sounds like this might be an issue with the sensor on the fuser. Where exactly is this located and how do I test this or attempt to fix this? Thanks.
It is located on the fuser unit at the back of the printer. It typically has 3 wires going to it; a blue, red and black wire.
Posted on Nov 02, 2010
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Dell 1710 paper pickup roller bar does not drop down. Rollers do turn
Dell says throw it away. Dell Tech is $150 hr. 2 hr min. Cost prohibitive.
No user replacement parts available. Great system, I say with disgust.
Jan 24, 2010 | Dell 1710 Laser Printer
Dell Laserjet 1710 - won't take the paper from the tray
clean the paper pick up roller and check any paper pieces is there
Oct 05, 2009 | Dell 1710 Laser Printer
Paper feeder stops after in about 2 inches
Have you tried cleaning the feed rollers with rubbing alcohol or soapy water? Just make sure to dry the rollers before trying to use the printer again. If this doesn't remedy the problem, check the paper feed path for obstructions (previous misfeeds or jams). Hope this helps.
Sep 03, 2009 | Dell 1100 Laser Printer
Printer dell 1710,paper is always sticking,We used different kinds of papers and they all stick and now all the lights keeps flashing
If by sticking you mean jamming. One cause could be worn pick up rollers or possibly an issue with the fuser assembly.
Jul 06, 2009 | Dell 1710n Laser Printer
DELL 1710- PAPER JAM AFTER EXITING PAPER BIN!
Preface; I am a support tech for a major gov't facility and we have hundreds of the Dell printers and PC's.
2 possible solutions. I have seen both. Items can get stuck in the paper path in the guide area, this is just before the pressure roller plate, this is the plastic piece under the fuser roller assy. The rounded plastic piece that guides the paper from the tray into the print area can have paper scraps or objects such as rubber bands, staples or paper clips caught inside of it. This can happen if any of these things get in the paper tray. I just pulled a rubber band out of one of these today.
Many times it is the paper sensor that is located under the pressure roller plate. After you remove the fuser asy you can see a plastic 'finger' that is just right of center in the pressure roller. There is another one a little further in and it is more center line on the 'floor' of the printer.
I have seen these go out with fair regularity. If you remove the paper tray and turn the printer on its side you can find the body of this sensor under the feed roller/arm asy that drops down into the tray to start the feed process. It has some white, plastice type material and wires running out of it. It is held in by a single screw. There is another sensor of the same design located by the pivot point for the feed arm. If the paper gets by the first sensor then stops, it is the second sensor that is out.
Oct 21, 2008 | Dell 1710 Laser Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Paper cannot pass the Fuser/pressure rollers
We have many of the 1700N printers and have found that the 2 paper pickup tires must be in good condition to avoid frequent jams. I would highly suggest replacing the 2 paper pickup tires if this printer has a lot of copies on it.You can slip the tires off of the plastic roller and see if they are shiny. If so, replace them.
Aug 12, 2008 | Dell 1710n Laser Printer
Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Dec 12, 2007 | Dell 1710 Laser Printer
Dell 1710 Laser Printer Logo
259 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
