Star Logic 17" LCD Monitor Logo
Posted on Sep 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen distortion 3 inches of the left side of my screen all the way down has a redish pinkish haze help?
Scott Hill
Level 3:
  • Master 558 Answers
  • Posted on Dec 03, 2008
Scott Hill
Master
Level 3:
Answers
558
Questions
Helped
283246
Points
1091
Bad ccfl lamp you will need a new screen, or if you are adventureous a new lamp on that side and alot of patience to replace it lamps require soldering if you can get to them at all.
happy holidyas hope this helps
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
FINE LINES HORIZONTALLY ACROSS SCREEN, ABOUT 2 INCHES FROM TOP. SCREEN IS DISTORTED ABOVE THESE LINES
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
The picture is not clear. It has a red/greenish haze or gloss over the screen which distorts the sharpness. The manual controls do not help. What can I do?
The color is distorted on the lower left hand side of the TV, or maybe distorted is not the correct wording. It looks like there is a yellow haze in that corner...
hello my name is rico, i work on tvs sometimes. The model of tv you have is very common bad light engine, because you mention there is yellow haze on lower left corner, if you need more help please feel free to call me anytime, i live in mesa az at 602-810-7149. And is not worth to get fix because the L.E. will cost you between $500.00-1000.00.
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
3helpful
The camera has started giving me a redish display.
image formation is defective,C.C.D. failed ,replce with a new one.
2helpful
2answers
The whites are not as white and there is starting to have a slight pinkish purpleish haze around the edges around the screen its not bad yet but I have tow and you can see that it is not as bright as the...
When an LCD starts getting pinkish to redish hues, the screen is starting to fail. You are in the biggining stages of losing the screen. There is no repair....only replacement.
Blue Haze comes out the left side of screen top to bottom about 3 or 4 inches.
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
1helpful
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Yellow Haze Center Screen
Top Star Logic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
