Question about Kitchen Ranges
Oven element in IAG stove suddenly wont heat past approx 100dg does glow a dull red .Grill element ok
  • 1 more comment
  • michael203 Dec 27, 2008
    I have the same problem! did you find a solution?
  • mickyman Apr 26, 2009
    have the same problem, I also found if i DIDN'T use the fan the oven increased in temp, but as soon as the fan was used the temp went to about 100. if i used the top element only i could get the temp up higher.
  • angelsperch May 17, 2009
    Exactly the same - oven won't heat past 100 degrees. Think it may need specific knob position combinations but don't have a manual.
    Angela
Sounds like the thermostat is faulty but odd that both ovens fail to the same degree. It would probably be worth having the thermostat tested. Our IAG IOM6SE2 had the beeper volume go to a quarter volume - perhaps a similar problem. It is under warranty but IAG are not too keen to fix it. They first said, if it is a setting then we will bill you, and then, if it was caused by a power outage then it is not covered. (How can you tell?) They also suggested we claim against our home insurance. I have tried to find a service manual on the web, but no luck.  If I had a circuit diagram I could be of more help.
Posted on Apr 08, 2009
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Electrolux cooker oven
probably a element failure, the element should read approx 30 Ohms when tested with a multimeter if no reading or substantially more than this it will need replacing
Apr 04, 2014 | Ovens
Oven has stopped working on zanussi zbf 360
Heating element is probably shot. Turn it on....does the element glow orange????
Mar 13, 2012 | Zanussi ZBF360 Electric Single Oven
The oven heating element seems to be working but the fan is not working. It appears that the oven is reaching temp very quick and there is a red glow coming from the back of the oven which is where I...
If you can see the element heating up, but the fan is not working, then you need to replace the fan motor assy, if you do not, then the element is in danger of burning out.
Jun 23, 2011 | Ovens
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Miele Oven H316 When using fan forced the area behind the back plate where the fan is glows very red. If stop fan forced cooking and revert to normal conventional heating red glow does not appear. Fan...
element should glow dull red when on fan oven but not bright red. are you sure fan is operating? remember there are two fans - oven fan and casing fan and you may be listening to casing fan
Nov 17, 2008 | Kitchen Ranges
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
700 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
