Question about Dell 1710n Laser Printer
Paper jam on back rollers
The Dell 1710 Printer we have prints 2/3 of the page and then stops with about 2 inches sticking out past the back rollers. What are the steps to troubleshoot these to determine the problem? How do I test to see if it is the fusers, sensors, drum roll, etc.? Thanks.
  • toner guru Dec 09, 2008
    I have a similar issue but it is only happening on large PDF files. Everything else prints correctly. I reinstalled the drivers and updated the firmware. However, the issue remains. Solutions....
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Posted on Oct 24, 2008
Paper jam light is on
Look real close. It is difficult to see very small pieces of paper that coudl be lodged in many areas. Also if you take a clean cloth with a little rubbing alchol and clean the sensors, this may help
Jun 17, 2010 | Dell 1710 Laser Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Printer dell 1710,paper is always sticking,We used different kinds of papers and they all stick and now all the lights keeps flashing
If by sticking you mean jamming. One cause could be worn pick up rollers or possibly an issue with the fuser assembly.
Jul 06, 2009 | Dell 1710n Laser Printer
ML-1710 Printer won't print
Our printer at work does this and I found that a piece of paper was stuck under the rollers. As soon as I removed it the paper went through. Another problem could be that you may need to FAN the paper and make sure the other side is feeding in first. Hope this help
Mar 20, 2009 | Samsung ML 1710 Laser Printer
Dell 1710 jam
It is located on the fuser unit at the back of the printer. It typically has 3 wires going to it; a blue, red and black wire.
Sep 15, 2008 | Dell 1710 Laser Printer
Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Dec 12, 2007 | Dell 1710 Laser Printer
Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Paper jam / Dell 1710n
Do this You want to check the paperpath so first run a test page you will hear the paper pickup if you stick your ear to the paper tray it should pickup paper within 2 clicks any more than that that means you would need to change the bottom roller and the pad on the tray to be safe, to print a job the printer is timed to do this so if your paper is not picking up in time it will jam (also your fuser the part that heats up the toner on the paper it has a time limit to heat up if it's slow or don't heat up at all you will get a paper jam plus if that happens take your finger and run it across the paper if toner on your finger it's you fuser
Sep 12, 2007 | Dell 1710n Laser Printer
Dell 1710n Laser Printer Logo
606 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
