Question about Acer AL1917W LCD Monitor
No Sound? I have no sound coming out of my built in speakers. I figured out I needed to download a driver, because I have lot my CD. And I installed the driver, and followed the directions of unzipping and upgrading your driver but when I select the unzipped file to search it says cannot continue the hardware update wizard . What do I do ?
  • 1 more comment
  • Treeese Oct 12, 2008
    It is an Acer AL1917W .
    My cables are plugged in correctly, I still cannot hear any sound .
  • Anonymous Nov 13, 2008
    mkjlkl
  • Treeese Jan 17, 2009
    All I know is that my dad had reformatted my computer or something , and when he was done with it the audio was gone .
    Hope that helps =\
Speakers do not use any drivers. The driver is associated with your sound card, and not the speakers. It is thus importaint for you to identify the sound card in order to find the correct driver. If your computer came with a built in (part of the motherboard) sound card (i.e. it has a blue, green and yellow/pink jack directly on the motherboard) the driver should be on the motherboard CD - refer to the motherboard make and model (usually written on the motherboard) to find the right driver for download if you do not have the CD. If the sound jacks are on a seperate card (PCI) that plugs into the motherboard, see if you cannot read the make and model number from the card itself, and use this to find the right driver for download. Most manufacturers have a support site where drivers for their products are available for download. Ensure that you get the driver for the operating system you use (e.g. XP driver if you use XP etc, as there are normally different drivers for different Operating Systems. A simple Internet (Google) search using the make, model number and the words "audio driver" should put you on the right track.
There are several other reasons the sound may not work, and it may be a good idea to first troubleshoot the source of the problem. e.g. If onboard, the sound could be turned of in the BIOS, the speakers may be faulty and do not work even with correct input, the sound could be muted etc. If you supply more info regarding your sound card and the symptoms, I may be of further assistance.
Cheers
PoisonedPawn
South Africa
Posted on Dec 10, 2008
    Sergeant:
  • 300 Answers
The driver seems to be unable to launch , this can be caused by a corupt driver file
Try downloading the file again , if the same thing happens , it may be because no previos driver was installed and therefore the updated driver can not update the original display driver
This may be one of those situations where you may need the original driver from the CD
Or it could mean you need to update your display by other means.
Let me know what happens.
Selah.
Posted on Sep 15, 2008
  • Steven Brown Sep 16, 2008
    Can you tell me what monitor you have and what model ?
    Most monitors do not require a driver to make their speakers work !
    below is an example of a VGA cable with a green tip audio cable as for it's speakers.
    the other end is the same with a green tip 1/8 , which plugs into the audio ports of your computer.
    Az.
No sound coming from built in speaker
Is your computer custom built? Or a factory built one? If it's factory built I'm going to need the model name.. For an example I have a Dell A950. It's name can normally be found on the front or back.
I need this because I can't help you solve your problem if I have no idea what hardware you have. Therefore I can't know where to get the driver to fix your speaker. The built in speaker probably needs a specific driver to be used.
Apr 09, 2013 | Computers & Internet
I plugged in my speakers to Compaq Presiaro computer, and get no sound. New batteries are in, what should I look for? Do I need to download something for these to work?
Hello Debkopper, Hi!, No sound output can be several things. so lets do this one at a time. No sound means: 1. mute or low volume setting. check your volume controls. If you can find the volume controls, 2. look at the lower right side of your monitor, (if you are using Windows7 or xp) you should see a speaker ICON. click it and set the volume. If you have no speaker ICON, then 3. you need the driver software to activate the sound section of your PC. if you have the CD of the PC motherboard, use the CD to install the driver. IF you have a SOUND CARD, locate the CD that comes with it when you purchase it. If the sound card comes with your PC. locate its CD driver. 4. NO CD, then browse the internet to download the driver software. Here are info of what you need jot this down..... the motherboard make and model. (If sound card then the make and model) 5. After download install the driver.
IF you cannot find the driver or simply tired to find what it is, BUY a USB type SOUND CARD. plug it on a spare USB port, then your done, instant sound!!!
Dec 07, 2010 | Labtec LCS 150 Computer Speakers
My speakers are not working. I do not have a CD. Can I get a download?
Are the speakers themselves not working, or is the problem that the computer's sound isn't working? You can test the speakers by plugging them into an iPod or other device. If they aren't working that way either, you'll need to repair or replace the speakers.
If the speakers work on another source, the trouble is in the computer. Reinstalling the sound drivers often solves "no sound" problems. The drivers may already be in a folder on the hard disk (most manufacturers have a drivers folder somewhere). If not, you can download the drivers from the computer maker's website.
If there's still no sound after reinstalling the drivers, the sound card is bad. If the sound is built onto the motherboard (the usual case), you can install a PCI sound card as a replacement. They aren't expensive and you can find them at large retailers or online.
Good luck, and thanks for using Fixya!
Oct 19, 2010 | Harman Kardon Audio Players & Recorders
Had sound. did a reformat, now no sound. what to do???
install your sound driver, on MY Computer right click then properties then device manager, check if your sound card is not yet installed, then find the cd driver that comes with your pc, after that install the driver of your sound card from the cd, if you lost the cd download cpu-z to determine your sound card then download it online, or to its respective manufacturer
Sep 27, 2010 | Polk Audio Audio Players & Recorders
My kinyo speakers have not worked since I changed my hard drive. Do I need a sound card? HELP
Good day sir, you need to load the device driver for your motherboard sound card, check your packaging for the CD that comes with your PC.
Jan 18, 2010 | Kinyo PS-107 Computer Speakers
I cannot get any sound output from my Acer Aspire T180 desktop PC. I changed the monitor from the original "out of the box" monitor. I have plugged in media speakers but there still is no sound output.
Sounds like a driver problem.
You should be able to get a universal Realtek driver from here.....
http://www.everydriver.com/?t=computer&m=realtek&p=download%20drivers%20for%20realtek&gclid=CIzMwe2-_ZwCFc0B4wodGHlNag
Sep 19, 2009 | Acer Aspire™ T180 PC Desktop
No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
http://www.logitech.com/index.cfm/downlo...
if you still have a problem try
http://logitech-en-amr.custhelp.com/cgi-...
Hope this helps :)
Sep 15, 2009 | Logitech R-10 Computer Speakers
Lost the installation CD for my creative SBS 240 speakers
u can download them from www.creative.com or search in google for creative speakers. then click the first link and in that go to supprt and drivers , in that choose ur model.
Aug 21, 2009 | Creative Labs SBS240 Computer Speakers
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
No Sound from my speakers
It is your sound card that you need a driver for not the speakers. Common built in soundcards are by Realtec. You can check by going to your Control Panel and Sounds And Devices and go to Hardware. You can also check out everything by going to Start, Run, DXdiag, Enter. Here is the driver download site for Realtec.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
You also need DirectX 9, you can get it here
http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
Nov 07, 2007 | Audio Players & Recorders
Acer AL1917W LCD Monitor Logo
754 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
