Question about Samsung HL-S6186W 61" HDTV
Samsung HL56186W Fan question
I saw that you posted a answer regarding the cooling fans on this tv. Could you tell me where the 2 cooling fans are located. I have found one and it seems to be working but I could not locate the second one. The one I found was in the center in the rear of the TV next to the light bulb. Any help that you may have would be greatly appreciated. THx.
5 Suggested Answers
  • 1694 Answers
SOURCE: My Samsund DLP Rear Projection TV keeps turning itself off.
solder bad connections on power supply pcb.......T.
Posted on Dec 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Posted on Jan 18, 2009
  • 41 Answers
SOURCE: Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
Posted on May 18, 2009
Slinteriors
  • 8617 Answers
SOURCE: Obtain repair manual for Samsung DLP projection TV's.
You can get the service manual by download link within minutes from the following link. Just scroll down the page and you will see your model listed.
http://www.tvrepairworld.com/service_manuals
Posted on Dec 24, 2009
Testimonial: "Your solution was very timely and helpful. Thanks"
ladywinn
  • 5138 Answers
SOURCE: Getting a check Fan no. 2 fault. both fans seem
Lamp Call Mats 1-800-628-1118
Posted on Jan 22, 2010
WHERE IS THE ELECTRIC FAN TEMP SENSOR ON A 2007 SUZUKI XL7
-Most of cooling fan temperature sensor in locate next to the thermostat housing.
Good Luck
Mai
Aug 27, 2015 | 2007 Suzuki XL-7
Samsung hdtv hums
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 2 hours and let the tv cool and replug to AC power and redo the cabling. Switch on the TV and see if it works..if the fan does not run then you may need to replace the fan as its vital part which cools the tv part ,to fix this issue....
And use his link to replace the cooling fan....
http://www.jangro.com/a/2006/09/29/samsung-dlp-how-to-replace-fan-2/
Good luck...
Sep 23, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Where is the cooling fan control located on a 1999 jeep chrekee
cooling of the engine? or you, A/c? cooling.
guess at engine cooling....
deep in side the PCM is answer
better, its now software , there. .
the pcm on new cars, have a EFI sensor called ECT
the designers woke up one day, and said hark, why have 3 sensors
1 for fan
2 for A/c
3 for EFI.
answer, was, you don't.
the FSM is free, to see, and look at that.
why not post the symptoms so we can tell you what is wrong and not guess.?
The ECT is the main engine coolant temp sensor
if this sensor is over about 215f, they PCM closes the rad coo
i must warn you , if you dont have A/c as some dont. the engine has
a fan clutch, as fully stated in the FSM.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
free to look, posted 100s of times here. but there it is,
see engine cooling chapter.
then see the schematic for the wiring of the fan relay.
both pages tell you what you have.
if its HVAC cooling, then see HVAC
May 03, 2014 | 1999 Jeep Cherokee
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
Where on my motherboard do I plug in the 2 fans that came unplugged while cleaning?
Here is a detailed layout for the fans for your motherboard:
This is a part from page 52 from the Asus manual.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 07, 2011 | ASUS M4A79T Deluxe - Motherboard - ATX -...
Replaced lamp on samsung hlp5063w set still broke fan is definatly not running cant find replacement fan
You can get the replacement fans for your samsung at the following link. www.tvrepairworld.com you can call them to see if they have them, But they should they dont list all there parts only the high demand items are listed.
Dec 23, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My dvd player keeps saying fanchk and then tuns its self off
Hi JB,
It's telling you to check the cooling fan on the unit. Electronics are dust magnets. Sometimes the fans get jammed.
At any rate, make sure trhe fan is functioning and clear of dust molecules.
BEST regards
Mike
Dec 19, 2009 | Samsung Audio Players & Recorders
Cooling Mode On
Not my answer, per se. Saw this on another site recently, so posted it for you. The answerer says he's a 40+ year GM tech:
Hello, the cooling fan is designed to come on when and if the temperature exceeds 223 degrees or if the AC freon pressure exceeds 190 psi. So, you were on the right track but did not let the temp get high enough to activate the cooling fan. If the temp exceeds 230 degrees or the pressure exceeds 240 psi, then the high speed fan comes on. Normally in the second condition the engine light will also come on and set a DTC code so the system can have diagnostics run on it. Because the fans are controlled by the PCM (power train control module) and they are a class 2 electronic device, the proper way to test them is with a class 2 scan tool so the relays and temperature sensors can all be tested together. That way if there is a malfunction in the system, it will show up on the scan tool. About the only things that can be tested without the scan tool is the fan motors themselves, by simply installing a fused jumper wire to them one at a time. Thanks
Read more: http://www.justanswer.com/questions/1g63n-2007-chevy-cobalt-2-day-hour#ixzz0KtkpBeMk&C
Jul 10, 2009 | 2007 Chevrolet Cobalt Coupe
Check fan # 2
Samsung Consumer LCD tv's do not have fans except on the higher end models. The Commercial models do. Yours is a Consumer model. I suspect that you have a DLP tv. In that case replace the Lamp Fan. It is the Larger of the three fans. With the rear cover off, you will see a Blue switch lever on the lower right side of the tv. Hold it in a up position and turn "on" the set with your tv remote. Then look for any fan that is not running. Then order that fan. there is a large fan that cools the Lamp. The other fans are of the same smaller size and one cools the DND chip and the other cools the Ballast.
Jul 04, 2009 | Samsung Televison & Video
It's been a while since I had to clean the fans, from memory, there was a small fan close to the base of the removable lamp assembly, and the larger one with a shroud directing the airflow round the lamp.
Hope that helps.
Sep 15, 2008 | Televison & Video
Samsung HL-S6186W 61" HDTV Logo
144 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
