Question about Amana AFD2535DES French Door Refrigerator
Amana AFD2535DEW trips circuit breaker
Sigh. Had to replace the relay overload just 2 months ago (July). Today the power just went off. We discovered the circuit breaker tripped. Reset it, tried to plug in refrigerator again. Motor tries to start, then trips the breaker again.
Wondering if this is related to previous problem or previous solution wasn't really the problem, just a precursor to this.
Thanks in advance for any help.
Robbie
  • Anonymous Oct 13, 2008
    I have the same problem. Please post if anyone knows the solution to the problem.
  • 124 Answers
SOURCE: My Amana refrigerator freezer is totally off.
Ouch!
You may have lost your fridge. Try This.
  1. Unplug.
  2. Take a table lamp & plug into socket where you had fridge plugged in. Turn light on. If it lights. Fridge is trouble.
  3. If no light check another socket make sure light works if it works your socket, wiring or breaker is your problem.
  1. If fridge check wire to & from fridge make sure it is unplugged feel & look for crimp or gap in wire.
  2. Check connection to fridge some have a reset button or overload fuse. Reset or replace if you find one.
  1. If socket try another socket see if fridge runs.
  2. If it runs you will have to troubleshoot house wiring.
Contact me if you need more help. Good Luck!
Please rate if this fixed or was helpful. Thank you.
Posted on Mar 09, 2009
  • 400 Answers
SOURCE: Amana sxd524v fridge-freezer tripped out the power
Hi, you can check if there is a fanmotor on the condenser section and make sure that it is working. Second, you can try replacing the starter relay which you will find in the connection area of the compressor. If this does not work, I am afraid you would have to have the compressor replaced.
Posted on Mar 13, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have an Amana bottom freezer refrigerator, model
There's a good chance your compressor is the problem. Since it's been working I would try it with another relay since they are pretty cheap. If it's not the relay, you'll need a tech to replace the compressor or fix the freon leak and recharge the system.
Posted on Jan 26, 2010
  • 572 Answers
SOURCE: Is there a reset button on an Amana side by side refrigerator?
check the compressor relay.
Posted on Feb 08, 2010
SOURCE: refrigerator trips circuit breaker
try standing it upside down for a day it will work
Posted on May 28, 2010
York affinity 9.s series, year 2008. I have not used my furnace since last winter (approximately 7 months ago). I went to start it up this year for the first time and it will not start. Upon inspecting...
Fuses will blow if there is an overload.
Breakers only trip if there is a short to ground.
Since you replaced the fuse and it blew and tripped the breaker , I would check for a wire problem. Also check the elements that rodents haven't built nests ect...
Nov 12, 2014 | Heating & Cooling
Stelrad ideal mexico super cf100 - electrical problem
There are a couple of things that can be causing your problem. 1. The controller is bad which is tripping the breaker. 2. The breaker needs to be checked or replaced. 3. circuit overload by to many appliances. In any event you will need qualified technicians to do repair. My guess is to start with the controller and have it checked because of its age. After this is done get an electrician if necessary. The kitchen circuit may be a separate issue or part of the problem. If your kitchen or an appliance in it like a stove, fridge or microwave is on the same circuit this will cause a possible overload and trip the breaker. If your kitchen is on a separate circuit and you added another appliance this could cause an overload if in use at the same time.
Mar 30, 2017 | Water Heaters
My lights dim and microwave fan slows when turning on toaster
ABSOLUTE FIRE DANGER
Do NOT keep overloading circuit until electric is brought up to code.
Voltage drop.
Your breaker is rated more amps than the wire ... so wire is getting hot ... and appliances are starved for power.
The breaker should trip, but somebody has put in larger breaker without installing larger wire.
So wire is getting hot as appliances draw more power than wire can safely carry ... but the breaker should trip when wire gets hot ... but breaker is not tripping because it is oversized.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Microwave should be on dedicated 20 amp circuit ... which means 1 breaker supplies voltage to microwave and nothing else. This is code today.
Mar 21, 2013 | Home
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
I have a Amana PTAC model PTC123A50AC never had any problems until this a.m. walked into office were installed no heat. Breaker tripped, reset breaker, nothing. Checked outlet, getting power. Any idea's?
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
Jan 11, 2011 | Amana Heating & Cooling
No power to dryer but have power at house...is there a reset button?
Check the circuit breaker in your housepanel. If it is tripped, resetting it will restore power BUT usually there is a reason for the breaker to trip. There may be an electrical problem with the dryer either an overload condition or a short circuit so check it's operation to be safe. If the breaker won't reset, unplug the dryer. If the breaker resets, then you have a problem in the dryer. if it still won't reset, then you have a problem in the wiring to the dryer outlet.
Nov 28, 2010 | Amana NDE2335AY Electric Dryer
I have a 1995 Buick Century that out of the blue last night, the dash lights, headlights, radio, and dome light quit working. Today I checked the fuses, unplugged the battery to reset the ECM, and fished...
There could be a timed circuit breaker:
Circuit Breakers The headlights are protected by a circuit breaker in the headlamp switch. If the circuit breaker trips, the headlights will either flash on and off, or stay off altogether. The circuit breaker rests automatically after the overload is removed. The windshield wipers are also protected by a circuit breaker. If the motor overheats, the circuit breaker will trip, remaining off until the motor cools or the overload is removed. One common cause of overheating is operation of the wipers in heavy snow. The circuit breakers for the power door locks and power windows are located in the fuse box.
Oct 13, 2010 | 1995 Buick Century
Frig keeps overloading circuit breaker, just repaced relay
I think the compressor has a problem with its internal running coil , or it's grounded.To check it you can disconect the power to the compressor and then turn on the breaker , and if doesn't tripped the breaker ,you know the compressor is bad.
Sep 06, 2009 | Refrigerators
Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Amana AFD2535DES French Door Refrigerator Logo
106 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
