Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
No video, shuts off then back on
Turned the set on and there was no picture, just sound. After about 15 seconds the tv powered itself off and turned itself back on. It just keeps doing this over and over until I power it off myself. I've tried unplugging it and plugging it back in with no help.
  • 1 more comment
  • Anonymous Oct 29, 2008
    I have the same problem, only while we were watching there was just a loud pop noise and the screen went black, now when we turn on the TV it does the same thing your TV is doing, the audio comes on but now video. Did you replace the bulb? If so, how and where did you replace it?
  • timm1 Nov 03, 2008
    I replaced the bulb two weeks ago and it's starting to do the same thing again. The tv powers up and I only get audio, then the green light starts flashing. The tv then powers down and tries to restart itself. Is there something else I need to do when replacing the bulb?
  • Anonymous Nov 22, 2008
    same thing happens to me bulb blew already. my tv has really dark picture tried every thing . Think i need to replace bulb
  • 3 Answers
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Posted on Sep 16, 2008
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
The screen went blank and green light started flashing. Turned off the TV and let it cool. Turned it back on, getting sound but no picture. Red light is on, after about 15 seconds the green light blinks...
Since you say that there is sound but no picture, the first thing I would check would be the status of the lamp. I believe that the lamp has been shattered or the filament is blown. Please verify this and let me know
Feb 25, 2011 | Toshiba 52HM95 52" HDTV Projection...
Last night the set just turned off by itself. When I try to power on, the power light comes on for a second and then it shuts itself off again.
I am having this exact problem. The TV turned off by itself and now when I try to turn it on, the power light stays on for a sec and goes of with a click sound.
Any TV experts who can HELP?
Apr 20, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Help me
Either lamp or ballast(driver) bad, likely.
Apr 07, 2010 | Philips Magnavox 51MP392H Rear Projection...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
We have a Samsung HLP5674WX/XAA which seems to have a mind of it's own. It will automatically shut off or when we turn it own, there will be no picture with sound or once it turns on, the TV will shut...
I have a Samsung HLP5474WX/XAA. The ballast was replace 2 months ago. I just installed the lamp, i notice green flashing occur on the LAMP when i turn it on. The tv takes 10 to 15 second to turn on the picture, the sound as soon as i power up i can hear it. Any advice??
Mar 18, 2008 | Televison & Video
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
TV pops and shuts off
Its two maybe three issues that your having trouble with. First thing is the convergence. That problem could be a cold solder connection on the convergence IC's or the Ic's have a thermal problem, as after they heat up they go bad. The second is the popping. This could be an issue with the rear channel Audio output Ic intermittanly shorting and shutting down the set, or it could be a bad ground around the picture tubes, or a leaky hi voltage block, or a second anode lead going to the picture tubes could be split. The other common problem with this set is the STR#### regulator IC in the power supply. Now unless your a tech you shouldnt attempt any of these repairs as there is very high voltage in this set and could cause great harm to you. seek the help of an authorized repair shop for Toshiba. Try this # if you cant find one in your area 800-457-7777 Good Luck
Jun 09, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
653 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
