I want to uninstall adobe reader 8 - Computers & Internet
  • Anonymous Apr 21, 2009
    What if, in add or remove programs there is no REMOVE button for Adobe. Further, when you use the uninstaller in from the start menu it won't un-install correctly it comes back with a missing file error.
    Re-installing over the top (which often works) when un-installation files are corrupt doesn't work - it simply installs a SECOND version of ADOBE.
    The Installation CONTINUES to work however i'm caught in an update error loop (that's why I started the whole un-install process to begin with).
    Strange bx
    Sergeant:
  • 234 Answers
Hai! click START menu->ALL PROGRAMS->click the abode reader8->click the uninstall
(otherwise)
Goto->START->CONTROL PANEL->ADD OR REMOVE PROGRAM->you can see the abode reader 8 JUST single click and CLICK REMOVE! After that you can install whenever you want!
Posted on Sep 15, 2008
3 Suggested Answers
fwadley
  • 482 Answers
SOURCE: Adobe Reader 8 error, the procedure entry point could not be located in the dll
when you unistall something you need to restart the computer each time. then reinstall it.
Posted on Mar 17, 2008
SOURCE: Adobe Acrobat 8 error 2711
Sounds menacing but it’s fairly easy to fix.
Heres how to fix it:
  1. Download msicuu2.exe (Windows Install Cleanup Utility) from Microsoft, or by clicking on the file name.
  2. Run msicuu2.exe
  3. You will then get a message asking if you wish to roll back the in progress installation. You do.
  4. Install Adobe Acrobat or Reader 8.
Adobe’s more intrusive way of fixing it:
  1. Click Start>Run, type in regedit then hit enter or press ok.
  2. Back up your registry (not actually mentioned by adobe but a good idea whenever you’re about to make changes to the registry)
  3. Look for Key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Inprogress
    and delete the key if it exists.
Posted on Sep 10, 2008
My adobe acrobat reader was working yesterday but today it said the adobe acrobat reader that is running can not be used to veiw pdf files adobe acrobat reader 8 or 9 is required but that is what i have on...
Ensure that you only have one version of Adobe Acrobat installed. I've found that often enough, if Reader and the full version of Acrobat are installed at the same time, it can cause problems like these.
If that is the case, try uninstalling Reader, so that only Acrobat Standard remains.
May 05, 2011 | Adobe Computers & Internet
Unable to upgrade my Adobe reader 8.2.2.217 I get error msg 1612, which which states it can't find the installation source and asks me to verify there is one.
If it's Adobe reader then you need to uninstall your current version and download the latest version from the Adobe website and install from fresh. www.adobe.com Your error message should go away.
Jan 10, 2011 | Adobe Acrobat 8 Upgrade: Windows
I have problem opening adobe pdf files. I have adobe 9 and 9.3 but does not open adobe files. It asks for adobe 4 and 7 or 8. I tried to download adobe 4,7 or 8. It says I have that version on my computer....
try the steps below:
1. Right-Click on the PDF file.
2. Select Properties
3. On the General tab,
3.1. Check the Opens with: if its set to Adobe Reader
If not, click the Change button and select Adobe Reader
If the same thing happens, Uninstall all Adobe Reader installed on your computer. It is an indication that the installation is corrupted that's why it is not being detected.
I suggest that you can try to use Foxit PDF Reader instead which for me I find very convenient in opening PDF files.
Please let me know if the following has been helpful.
Aug 20, 2010 | Adobe Computers & Internet
I had/have Adobe Reader 8.1.1 and recently installed Adobe 9
first uninstall adobe reader 9 and then adobe reader 8. After that re-install adobe reader 9.
it may work. try
SMB
Nov 24, 2009 | Computers & Internet
Adobe Reader 5 came with my computer and it tells me this is not compatible. I need 8 or 9.
First, uninstall Adobe Reader 5 from the control panel.
Then go to Adobe's site: www.adobe.com and download and install the latest version.
Nov 06, 2009 | Acer Computers>Laptops Aspire 5610-4491 PC...
I cannot uninstall adobe 8 reader
Download revo uninstller .. Locate adobe 8 and then click om uninstall, Select advanced and remove all registry entries , Restart the computer.
Sep 18, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Internet probs
u mean reader 8 and reader 9 u can uninstall it from add remove program in XP or program and features if not then download clean up utility from http://support.microsoft.com/kb/290301/ and run it and remove only reader 8 and re install from adobe site
Aug 19, 2009 | Microsoft Windows Vista Home Premium...
  2. Run msicuu2.exe
Mar 19, 2008 | Computers & Internet
Mar 17, 2008 | Computers & Internet
Damaged adobe reader 8 damaged
if you get this error message when you try to open a particular file. the problem could probably be in the .pdf file and not the software. if this is not the case, uninstall adobe reader completely and reinstall it. if this docent work. download the latest version of adobe reader from the adobe site and try installing it again.
Jun 10, 2007 | Adobe FirstWare Recover Pro 2004...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
