Question about Canon Elura 85 DV Digital Camcorder
Elura 85 The cassette will not retract into position to tape. It will close but not go down into postion only rejects all cassettes. You suggested get a head cleaner but it would not go down into the positon to clean on rejected this suggestion.
  • 3 Answers
I have exactly same problem. Sent to Canon service, they replaced the whole tape drive mechanism - 2 montsh later the problem is back again.
Posted on Apr 21, 2012
    Genius:
  • 1,667 Answers
I am not the person who made any suggestion to you. I happened to see your post when reading on this site.
When this type of problem ocures in any of the camcorders, this means that there is usually a mechanical fault with the loader mechanism. Another cause can be that there is a sensor fault with either a tape position sensor, or with the electronics that operates with the sensors, and the tape loader mechanism. If there is a servo fault the loader will also be commanded by the uPC to eject the tape.
Because of the way the camcorder is constructed and its sophistication, this is not something you can fix yourself. The electronics are mostly all SMD technology, and the mechanical parts are very fine as like in a mechanical wrist watch.
I would suggest that you get in touch with the manufacture service rep to arrange to have an estimate for repair. The service cost is not cheap for these types of devices. The work is time consuming and the replacement parts can be expensive. Get an estimate for service before making any decisions.
You may find that servicing your unit when it is out of warranty may not be worth the cost. If your unit is more than a few years old, you must consider that it may pay to get a new unit.
Jerry G.
Posted on Sep 15, 2008
My Canon Elura 60 is not working properly. The cassette will not load. I tried to change the power source to DC from battery, but it didn't solve the problem. The cassette tray loads fine without the...
Unfortunately, you will need to have your camcorder repaired. Inside of your mechanism there are several different components that can go bad and cause this problem. You might have a bad capstan motor or a bad gear. If you hear something spinning like crazy when you try and put a tape in, you have a issue with your capstan. Hope this info has helped you.
www.austintelstarservices.com
Sep 03, 2010 | Canon Elura 60 Mini DV Digital Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
CASSETTE ADAPTOR VW-TCA7E tab won't retract when I place the video camera cassette in the adaptor and close the cover. The triangle-shaped tab is on the left side of the adaptor and when it has not...
I had a similiar problem, or so I thought, but my son has just found that it needs a battery, which I did not even know, so maybe yours just needs a new battery? the cover is near the tab, hope this helps
Apr 20, 2009 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Won't accept minidv tapes
That happened to mine. I had to take the camera back to bestbuy where I bought it and get it fixed. I forget what was wrong with it. Something on the inside got screwed up. I think it was called dubbler or something like that.
Jan 04, 2008 | Canon Elura 85 DV Digital Camcorder
Digital camcorder
This is an issue Canon has recognized with some of their models. I suggest you go to the Canon website and see if you can find your their - I believe they are doing an out-of-warranty repair for the affected models.
Dec 25, 2007 | Canon Elura 70 Mini DV Digital Camcorder
Canona Elura 60 problem...
What a hunk of junk. Not a month after the warranty period expired, my Elura 60 would zoom out without warning and refused to stay zoomed in. I paid Canon to fix that problem.
Now, I'm on vacation (in the Carribean for more than 24 hours) and the unit wouldn't accept a tape. Every time I tried to load a tape, it would beep five times and then kick the tape out. So I tried taking all of the batteries and media out. That didn't work.
Next, I tried the drop method. I figured the unit is broken and I'm not going to pay again to get it fixed, so dropping it couldn't break it anymore than it already is. I let the unit fall onto the throw rug in the bathroom. In then tried to install a tape. Waddyaknow! It worked.
I can only reiterate again two things: dropping the camera from about 6" onto a carpeted surface over a tile floor seemed to clear up my "remove the cassette" problem, and the Elura 60 is a temperamental hunk of junk (although the recordings and playback are pretty good, when you can actually get a tape into the unit).
Nov 12, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Tape Ejection Problem
I have both the willful zoom and the unwilling cassette problems. In the past I have briefly fixed the zoom by opening the door and gently probing the cable to the zoom button. This only worked for a couple of weeks then reverted to same crazed performance. Then last month the "remove the cassette" madness started (bear in mind, I have only recorded perhaps 15 cassettes on this damn thing). Nothing worked. Until tonight when I simply lightly smacked the unit down flat on the manual resting on my desktop. Did this a few times and BOTH the zoom and cassette door started responding properly. I'll see how long this lasts, but it beats buying a new one or dealing with Canon. Never again.
May 10, 2007 | Canon Elura 70 Mini DV Digital Camcorder
Tape problem, Elura 100
I called the factory and they said to send it in for evaluation.  While packing it up, I dropped it and lo and behold it started working.   Even though it started working, I decided to send it in to the factory and they found something "loose" inside and repaired it at no charge.
Feb 27, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 85 DV Digital Camcorder Logo
184 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
