Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
2WIRE wireless router/DSL from AT&T
Here at home, we use the 2wire ethernet/wireless router/DSL to connect to the internet wirelessly with two computers(a laptop & a desktop ), the desktop using a Belkin Wireless G Desktop card. The desktop runs XP, the laptop, Vista. How can I configure it so we can share the printer wirelessly? The printer is in a seperate room hooked up to the laptop where the 2wire is located.
  • 2 more comments
  • rcnlodi Sep 15, 2008
    Yeah, but how do I access the printer so I may print? It's not a wireless printer, so how do I set it up so I can print while its hooked up to the laptop from another room, via the wireless 2WIRE?
  • rcnlodi Sep 16, 2008
    I had a little trouble with setting it up even after I followed your every step, but I got it to work as I had hoped it would. Thanks!
  • ravipatel111 Nov 27, 2008
    how can i make my printer to wireless in my 2wire router from at&t.?
  • Anonymous May 17, 2009
    i have three computers(a laptop & 2 desktops
    ), desktop #1 is connected to the gateway and i have a laptop and desktop #2 in another room. i have a wireless printer. i can get it to connect wirelessly desktop #1 but not the other two computers. i can hardwire the printer to the desktop #1 and then print wirelessly to the printer but desktop #1 has to be on.
I can fix it. You need a print server for your printer with usb or parallel cable port on one end and ethernet port on the other end. Connect the print server to router and printer, install necessary software driver it comes with and you would be all set. I have connected 1 usb and 1 parallel printer with router.
I hope it helps. My m/cs are identical to what you have as far as OS goes
Posted on Mar 17, 2009
    President:
  • 2,961 Answers
Unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Posted on Sep 15, 2008
  • andrew pester
    andrew pester Sep 15, 2008
    your question was "How can I configure it so we can share the printer wirelessly?"
    this means a wireless printer, you mean share the printer on a network, on the laptop go to start>network, then in the folders on left click printers and then click on printer properties and select share this printer or right click on your network icon in task bar>network and sharing centre and click printer sharing in network and discovery.
    Then go to your XP pc and open the printers folder on programmes or in control panel, select add printer, then choose network printer>browse for a printer and then it should be discovered and the drivers installed.
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Dec 22, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
4,899 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
