Question about Kicker KX600.1 Car Audio Amplifier
Protection light comes on when amplifier is hooked up
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Posted on Sep 15, 2008
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Protection light
double check the blue stereo input wire to amp is this a new amp if not speaker channels in amp might be blown
Nov 08, 2008 | Kicker KX120.2 Car Audio Amplifier
I really need ur hlp badley
If the protection light is lit, the amplifier probably has shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect mode - Troubleshooting
Nov 05, 2008 | Car Audio & Video
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Protection Light Is Coming On
try redoing the wires you might have wires touching somewhere if that dont stop it try new RCA wires
Jan 08, 2008 | Lanzar Vibe 235 Car Audio Amplifier
chenge and replace the safe of the amp
May 22, 2007 | Kole audio Q2-1920 Car Audio Amplifier
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Kicker KX600.1 Car Audio Amplifier Logo
120 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
