Question about Nokia N70 Cellular Phone
Phone in offline mode
Phone went to offline mode. While chaning the profile message appears - "insert sim card".
I replaced this SIM and inserted other, it asked 'whether you want to continue in offline mode y/n'. Its started working this time. When I inserted the previous SIM, it again went to offline mode.
Pls suggest a feasible solution.
  • 3 more comments
  • Anonymous Mar 01, 2009
    my phone is off line when i try changing the profile it says insert sim as well. ive taken it back to MTN to be fixed but was returned as is! This problem is disgusting as my phone is still new and nobody can seem to help.
  • Anonymous Mar 04, 2009
    I have the same problem help me pls :|
  • abdulhamed31
    abdulhamed31 Oct 14, 2012
    How to solve this problem, my Nokia 5800 Xpress Music is always at offline mode i cannot acces my sim card to my phone.
  • Anonymous Mar 17, 2014
    i inserted sim but it shows insert sim card
  • Anonymous Mar 20, 2014
    my phone N 72 is currently offline when I change my profiles into general or silent the message insert SIM card appears.Help
  • Nokia Master
  • 456 Answers
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Posted on Sep 29, 2008
  • Mohinder Kataria Jul 29, 2011
    I had the exact problem with my N70. What i did was to take the sim out and then use the power off button to dispaly the options for swtiching the phone off, including changing profiles. select the profile offline then do the same thing again and select a different profile the phone will ask you to insert the sim. disconnect the battery in the sim, when you switch on the phone it should ask you if you want to continue in offline mode, be careful to select NO. and voila. hope this works for you as it did me.
  • Aminul Islam
    Aminul Islam Nov 19, 2013
    Worked for me!
Nokia 5230 sim card not valid when sim card was inserted
I have a Nokia 5230 sim card not invalid sim message will throw
Sep 18, 2012 | Nokia 5230 Cell Phone
Message : Insert Sim Card
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Aug 24, 2012 | Nokia 6700 Slide Cell Phone
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
Jul 08, 2012 | Nokia E Series E7-00 Touch Smartphone-...
My phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
Jul 25, 2011 | Nokia N95 Cellular Phone
Nokai 6681 isgone to offline mode.
Hey Friend,
  • your SIM ic Damaged
  • Need to replace
  • Or Sim tray Damaged
  • OR sim not Properly inserted..
Is this Helped you.....
Rate me...
Thanks for Using FixYa
Mar 27, 2010 | Nokia 6681 Cellular Phone
NO SIM MODE
try these steps..
1. get another sim card insert it to your phone (this will help you troubleshoot the problem between phone and sim).
2. check the phone profile settings, if it's on offline mode, then select general, or silent , it's up to you but don't choose offline mode.
3. clean the contact surface of the sim card by pencil eraser and a piece of clean soft cloth.
4. reinsert and try.
Feb 17, 2010 | Samsung Star GT-S5233 Cell Phone
Can not get Nokia 6120c V04.21 to online mode
there might be problem with the sim card holder. try to insert some piece of paper folded atop the sim card and close the sim holder
Aug 12, 2009 | Nokia 6120 classic Cellular Phone
Nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
Jun 15, 2009 | Nokia e65 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Nokia N70 Cellular Phone Logo
2,026 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
