Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Flyback install Bad flyback. If I order a new one, will the flyback come with the red and black wires already. Not sure how to get the black wire off the flyback.
  • RCA Master
  • 5,138 Answers
IT twisted off turn clock wise and wirer should come out red is easyer to remove,1 goes to high voltage tripper red black goes to focus&screen drive controls.
Posted on Sep 15, 2008
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
Wires going to flyback transfomer
Wires going into the flyback are not removable but are integral to the flyback. The three wires comming out the flyback are the thick red one (anode button) which attaches to the tube is removed by pinching the button to release the clips on the tube. The other wire probably white is removed by unsoldering it from the small board on the neck of the tube and the 3rd and last wire is probably black, this is the one you may have your issue. To remove this wire, you must disassemble the tube socket..look for two tabs..pry open gently and seperate. Then with a small jewelers you'll be able to release the black wire..hope this helps.
Jan 25, 2009 | Televison & Video
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
RCA
The flyback is the big black thing on the deflection board. usally has big red wire coming out the top. THe three small rectangular items are special fusable resistor. or fuses
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Flyback 259296
When you remove the rear panel look to the left side of the chassis and you will see the Flyback with the two wires coming out of the top one is a large thick red wire the other is a small wire. You can get a new replacement at the following link under 50.00 which includes free shipping and free support to help you install it by on line instant message with a repair tech.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | RCA D52W19 52" Rear Projection Television
Phillips 60PP9202
Try removing the back panel and try to power up the set and see if you can determine if the popping sound is coming from the flyback, in case your not sure what a flyback is it has a large red wire coming out of the top of it. If thats where its coming from let me know as you may need a flyback.
Mar 27, 2008 | Philips 60P8342 60" Rear Projection...
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
