Question about Radio Communications
Grounding I have a 96 Freightliner and a Magnum S9 radio and everyone says when I transmit it sounds like I am talking out of a hole except when I run in rain or in the morning when the dew is on then they say I sound great and they can hear me for a long way away. Would this be a ground issue and where would the issue be? Do i need to ground the radio or the antanas better and how do you suggest? Thankyou for your help.
    Brigadier General:
  • 5,158 Answers
I'm almost guessing that you have mounted the antennas on the mirrors and they may have rubber bushings for mounts. you may need to get some ground straps and run them from the bases of each antenna to ground... leave some slack so the door is able to open and close properly.
Robert
Posted on Sep 15, 2008
Just buying magnum s9 radio can it be used on 11 metre band or has it got to be modified for 26-27 cept channels as i think its just a 10 metre radio please advise many thanks.
Hey,
The magnum S9 is factory set for the 10 Meter band but can be "tweaked" to get up into the 11 meter band...
check out this neat and easy mod:
http://www.radiomods.co.nz/magnums9mod.html
Hope this helps!,ben
Jan 13, 2011 | Magnum S9 Base CB Radio
Magnum s980 stopped giving me sound from speaker.also transmit scratchy.audio scratchy.
Pour gasoline inside of it and set it on fire for 5 minutes. When done crank up every thing that can be adjusted inside for more modulation and power. Cheap radio. CB junk.
Sep 12, 2010 | Magnum S9 Base CB Radio
Need pin wirong diagram for s9
Hi, Pin # 1. Shield- (ground). Pin # 2.Yellow - (Audio). Pin # 3- Red- ( Transmit ) Pin # 4. White- (receive) ....hope this was very helpful.....rate this solution on the four thumbs-up .thanks.
Sep 07, 2010 | Magnum S9 Base CB Radio
My magnum S9 wanders off freqency an the incoming starts sounding very scratchy, is there a mod ?
magnum s9 they seem to drift a bit on till they warm up my s9 dose the same on till it heats up then it comes ok
Jul 30, 2010 | Magnum S9 Base CB Radio
Wat power does this radio push
Generally All CB Radios will only push 4 watts. This is only if you have a SWR of 1:1
Jul 11, 2009 | Magnum S9 Base CB Radio
Magnum 257 it will not transmit on lsb or usb it will on am and f
With SSB you have to put audio on the carrier you cant just key the microphone and expect it to output a signal unless you talk into the microphone at the same time this is how SSB works.
So if you talk and the meter starts to move then its ok, if you talk or whistle and nothing moves then the circuit on the SSB side of the unit is faulty.
Nov 26, 2008 | Magnum 257 CB Radio
Radio Communications Logo
79 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
