SOURCE: Flashing PROTECT
This is often caused by a problem with the speakers or speaker wiring. A speaker wire that's pinched behind the head unit will cause this problem if it's shorted to dash metal or the deck chassis. The first thing to do is remove the head unit and inspect all the speaker wiring for bare spots or pinched spots. If everything looks okay, disconnect all four speakers from the deck and switch it on. If it still shows "protect" then you have a defective head unit. If not, then turn it off, re-connect one of the speakers, and turn it on again. Continue until you find the speaker output that puts the deck into protect mode.
SOURCE: How to turn off this blasted DEMO mode on MP235
Once in standby you have to press and hold the button to get into the menu. Once in the menu, you use the joystick control on the right to navigate to "Demo" and toggle it to "off" (can't remember off the top of my head... you either have to press the joystick in and hold it to toggle or just move it up/down...). Once done, just press Source to exit.
SOURCE: KRF-5030D i stand by mode
Does it go into standby when it's in another mode like : Cd or Video 1 or tape?
When you state that you checked the power amp IC's , how so did you do this?
Thanks n' let me know.
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
SOURCE: Kenwood kdc-135 clock issue
does this car stereo have a hook up for my ipod and how do i get it to work
