Question about NetGear RangeMax NEXT WNR834B Wireless Router
Internet faliure Hi, My modem is netgear DG834N and I am facing trouble with the internet the DSL is working but the internet indicator is OFF the message I get is Initialize LCP.
  • 6,487 Answers
This is a problem with your modem, you can try to reset the modem then reconfigure it back using the setup CD but the best way to solve this and check the modem is to call Netgear tech support and let one of their tech walk you through with that process , this is the number 1-888-638-4327 ...
Hope that helps..........
Posted on Sep 15, 2008
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    How to connect netgear fs108 to cable modem
    leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
    Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
    With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
    Any doubts further ? please clarify with me.... I am ready to help you....
    May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
    How can i access my router configuration to open port 3074?
    Open any web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, enter "192.168.0.1" and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
    Should be able to acces it from the web interface.
    Dec 18, 2009 | NetGear DG834N Router (DG834N-100AUS)
    The internet red light comes on on the d link modem regularly- sometimes for hours, rebooting does nothing often- it was supplied by aol DSL 2640R- I have had it for about six months and gradually the...
    hi der... usually this kinda issue most of the time lies with the service provider.. but also to play safe...if can u may try to get another modem to test the connection. well internet light turns red . possible reason :
    DSL keeps disconnecting - Frequent intermittent causes ur user id and password to be erased and therefore u need to reboot or may need to configure back
    2nd : u may sometimes face night dc , if tats the case its the ISP circuit problem.. ask them to come and change the circuit which gives u intrnet access.
    3rd : ur modem unable to save ur configuration ... therefore ur modem mite be at fault
    or u can contact the respective modem vendor to check if ur modem is at fault before calling ur isp .. this mite help u pal...
    TC...
    Jul 07, 2009 | D-Link Computers & Internet
    How to add a netgear wgr614 router to dsl modem
    The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
    Jan 05, 2009 | NetGear WGR614 Router
    Hook up
    Hi Cheryl,
    From your cable/dsl modem please take the cable that comes out of it that looks slightly larger than a phone cable and plug it into a port on your NetGear Wireless Router that is labeled either Internet or WAN. After that is done, unplug the power to both your cable/dsl modem and your wireless router. Plug the power back into the cable/dsl modem and wait about 30 seconds then do the same with the wireless router.
    Next on your computer, there should be a wireless icon by your clock near the bottom right corner of the screen. If you double on it, you will see a list of connections, yours will say Netgear and should have a good signal strength. Double on it and give it about 10 seconds to connect. Voila, you should be on the Internet.
    Please let me know if this solves your problem.
    Thanks,
    Adam
    Nov 28, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
    Problem in reconfiguring WGR614 v5 after reset
    You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
    Cheers !!
    Feb 24, 2008 | NetGear WGR614 Wireless Router
    NetGear RangeMax  NEXT WNR834B Wireless Router Logo
    87 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
