Setting up a toshiba tecra 9100 to output with composite (av) out plug but on the tv the computer is plugged into only shows the top left quarter of the computers screen,, can this be solved by adjusting the resolution or is there something else???
    Sergeant:
  • 300 Answers
Your tv may not support resolutions greater than composit 640x480@60Hz
If you plan to use composit signaling set everything to 640x480@60Hz
Selah :-)
Posted on Sep 15, 2008
Why doesn't my XBox 360 show a picture on the tv
Most likely a damaged AV output socket , possibly lifting of the solder joins,
Jun 11, 2014 | Microsoft Xbox 360 Console
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
No hard disk found
From what you describe, your 40GB should be compatible with Tecra 9100.
I'd suggest you reset the BIOS settings to the factory defaults, just to ensure there are no wierd settings. Have you managed to use any other HDD with your Tecra 9100 previously?
Have You checked for a BIOS update for this model / vintage ?
Oct 14, 2009 | Toshiba Tecra 9100 Laptops
How to replace TECRA 9100 cmos battery?
http://www.insidemylaptop.com/replace-rtc-battery-in-tecra-9100/
here is the link that shows with pitures so you can change.
Oct 11, 2009 | Toshiba Tecra 9100 Notebook
Toshiba tecra 9100 video output
Try reinstalling the video driver, make sure you have the latest correct version (ie. XP or Vista).
You might need to download the video driver from the Toshiba WEB site, and make sure you select the correct model laptop.
Jun 20, 2009 | Toshiba Tecra 9100 Notebook
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Dec 03, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Wireless error for tecra 9100
i have a full set of drivers for this machine but not sure how i cud send to you.
Jul 30, 2008 | Toshiba Tecra 9100 Notebook
Toshiba Tecra 9100; "output device error" message
No sound? The only solution I've found is to get a USB headset like the Logitech USB Headset 20. I have had this same problem with my Tecra 9100 for almost 6 months. I tried on a pair of USB Headset and it works! because it bypasses your internal soundcard. The downside is that if you have a great pair of speakers on your laptop, then it's kind of a waste that you can never use it. But at least, with this, you can now listen to CDs and chat on the internet
Oct 22, 2007 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
