Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven problem. Our GE XL44 has had a problem with the oven taking forever, and sometimes never, heating up. When we "baby" the oven and set it on 200 degrees, sometimes it will slowly begin to heat up. Often times, it will not heat at all. What could be the problem? This has been occurring for the past two years. The range is only 8 1/2 years old.
  • Anonymous Sep 18, 2008
    i have the top of the stove working but can't get the oven and borlier to work where do you ligth the pilot for the oven and borlier
  • 116 Answers
Only 81/2!! most are only expected to give you 5 good yrs anything else is extras. Your problem may be a defective gas valve (safety valve). Also it may be a defective ignitor - the more likely to go bad (if replacing stuff replace ignitor before safety valve. is there a glowing in the oven? does the flames come on any at all?
Post a response
Regards
Posted on Sep 20, 2008
GE gas oven spectra xl44 takes forever to preheat &sometimes will not
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Will all that said, more than likely the ignitor is bad in the oven, not drawing enough amperage to allow the safety valve to open. Even though the ignitor is lighting up and glowing, I'm 99% certain that this is the problem. Here is the part number for ignitor. WB2X9154 and can be ordered from any parts distributor or from a local supplier.
Jun 21, 2012 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Xl44-specta oven takes forever to get hot, ihave to put temp at 550 and still theoven doesnt get hot to cook anything
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101 ...
Aug 08, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
I have a GE xl44 gas oven/stove. I cleaned the
Change the Temp sencor for the self cleaning
Dec 05, 2009 | GE Kitchen Ranges
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
My GE XL44 doesn't heat up to full temperature.
There are several things to check.
1) check the broil element
The broil element participates in the preheat and if the element isn't working it will take forever to reach temp.If the element is good 2)check the broil relay
If the relay does not activate when you press"broil" the control needs to be repaired.They are a few more things to check but you can start with the above.
We rebuild these controls.
Regards,
Howard http://www.appliancetimers.com
Apr 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
243 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
