Toshiba satellite USB port is damaged
My USB port is is bent. Can I fix this?
  • blackbird29 Sep 15, 2008
    Thanks, I'm guessing it's the motherboard usb so I will bring it in for repair.
    President:
  • 1,257 Answers
If  the usb port is at the front side of the c.p.u then it can be replaced ,but if the usb port of the motherboard is damaged then you have to take it to any repairing centre and fix it for you......because it has to be replaced with any damaged motherboard usb port....Please don't do it yourself..
Posted on Sep 15, 2008
  • Deeps . Sep 15, 2008
    Great......
    It will be highly appreciated if you rate this solution..
My usb ports do not work on my toshiba satellite L455D-S5976 i can i fix it
Please check if one or more of the USB port is "shorted" (please check the metal inside of all of your laptop's USB ports). If they are in good shape, then it means your motherboard is dying.
Mar 06, 2014 | Toshiba Satellite L455DS5976 Notebook
USB port keeps turning off
Possibility
thumb drive error. Chances are, your thumb drive firmware is damaged. So a normal laptop USB port.
Solution
To repair damaged thumb drive firmware, the solution can be found on google seach engines. Example; Fir transcends flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
Dec 24, 2011 | Toshiba Satellite C655-S5056 NB PC w/...
I can`t use an external monitor connected by VGA port for my Toshiba Satellite M55 S331. I need to know if the port is damaged?
The M55 series does not output to external VGA automatically. You can either go into Setup (press F2 when computer is starting) or use FN F5 in Windows to toggle between LCD, monitor, or simultaneous output.
The monitor port should be standard, so as long as the plug on your monitor doesn't have any bent pins, it should work.
Jul 26, 2011 | Toshiba Satellite M55-S331 Notebook
2 usb ports on right side of toshiba satellite a505 loose, not usable because not in place
Hello geniet1:
If the USB ports are loose, then the computer is going to have to be disassembled for repair.You should have Toshiba, or a Toshiba authorized service center fix it. If I remember correctly,all you have to do with Toshiba laptops is just drop them off at UPS for repair.UPS sends them to Toshiba for free, and Toshiba returns the repaired laptop to you.
Apr 06, 2011 | Toshiba Satellite A505 Notebook
Usb damage
It wouldn't hurt to be honest about what happened with the service plan provider and see what they say. It would be a shame to have to replace your computer over a broken USB port. You can always purchase a USB hub which plugs into one USB port and supplies you with two or more USB ports.
Good Luck,
NOLA Tech
Jan 28, 2010 | Toshiba Satellite L305-S5894 Notebook
I have a toshiba satellite A-135 laptop that will not recognize anything plugged into the usb ports
Check to see if one of the USB ports is damaged. Sometimes they can be damaged and have connections touching the outside metal of the port which actually grounds the connection and will cause the other ports to not work either. If it is connected then use a flat tip screw driver (*with the machine off and battery out*) to make it not touch the outside of the usb port and try "other" USB ports that aren't damaged and see if it works. If it doesn't then you are looking at needing a new motherboard. Locate your closest ASP and take in for service, you can find them at support.toshiba.com.
Nov 15, 2009 | Toshiba Satellite A135-S2276 Notebook
Satellite ac connecting port damage how do i fix this problem
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
dissasembly instructions,you need to take out motherboard and take a look do you able to fix or need to exchange ac port
Jun 14, 2009 | Toshiba Satellite Pro A200-EZ2204X...
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
Toshiba satellite r15-S829 has no sound at all
The socket on the motherboard was physical damaged, you can't fix it by your self but component level technician only. so you better buy a USB sound converter to make sound out form USB port of the laptop rather to fix the motherboard.
Nov 15, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
653 people viewed this question
David Payne
David Payne
