It wont turn on there is no power getting to the battery
  • 68 Answers
Need more details sir . can you please explain
Posted on Sep 15, 2008
My Sumsung GT 1550 phone wont turn on
That screen you're seeing is the battery power level; if it's all black your battery is almost completely discharged. Connect your charger and let it sit over night and try it the next day. If you still get the same screen after that your battery is probably shot and needs replacement.
Aug 24, 2014 | Cell Phones
Tablet wont start
You can shut off battery first. Just for minute. And then try to turn on.
If it not work out you need recharge battery by external charger and then try to turn on.
Apr 17, 2014 | Computers & Internet
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
It wont turn on, and it wont charge. whats wrong with it?
The battery cell is completely down, remove the battery and get a battery booster to boost your battery for sometime before charging, if the battery mp3 did not still turn on, i advice you get another battery to power your mp3.
Compliments and wish you best of luck
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
MY 97 DODGE STRATUS WONT START, ITSGOT POWER AND WEN I TRY TO START IT I ONLY GET A CLICK NOISE, NOT THEDEAD BATTERY CLICKING NOISE JUST ONE CLICK AND THATS IT. I HAD STARTED IT TWENTY MINUTES PRIOR TO...
i believe if you remove the steering wheel upper and lower covers, there will be a button to push to allow the removal of the key..as for the no start, the battery light is on because of the alternator. Its faulty. the clicking sound could very well be the starter not having enough power reaching to turn it over again unless you put a power pack on it...try a brand new battery, test the alternator and removed the key..it is possible the the key not shutting off the way, is drawing power from the battery not allowing to start that way, causing what they call a "parasitic drain". charge battery, remove key. try that
Nov 07, 2009 | Dodge Stratus Cars & Trucks
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Car wont turn over
Sounds like either your starter solenoid is bad or the starter is bad.
Sep 11, 2009 | 1998 Ford Explorer
I have an Inspiron 5100 that wont turn on. Power supply is good, 20 volts output. I plugged it in and I get 10 battery flashes and wont turn on.
This normally means your battery has failed. Have you tried booting the laptop with the battery removed? It should boot fine without the battery and if so you will need to contact Dell about getting a replacement battery.
Jul 24, 2009 | Computers & Internet
Compaq presario notebook v6128tu won't turn on
You can try to remove that battery and try to turn it on again.
Sometimes this will happen if that don't work the remove the power supply and try to turn it on.
If you see the blue light around the power input then it's obviously getting power but it's redirecting it somehow which brings us to the battery again heh.
Let me know if this does not work
Happy Holidays
Dec 27, 2008 | HP Compaq Presario V6120us Notebook
Computers & Internet Logo
David Payne
David Payne
