Question about Kenmore Elite 45986 Front Load Washer
Loads interrupted with anywhere from 19 to 12 minutes left in the wash the washer stops and displays F06. what is the problem with this machine? it is only 9 months old.
  • schaf06 Sep 19, 2008
    Half way into the cycle, it stops and F-21 flashes.  The door is locked so I can't get any clothes out.
Interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Posted on Sep 17, 2008
What is Wrong with my whirlpool front load washing machine,Mod.#GHW9150PW1?
f06 relates to a motor fault....easiest fix is to replace the motor......
cheaper on ebay........cheers
Oct 13, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Duet GHW9150P Front Load Washer: i have a code it is f06 and then washer stops spin...
Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down.If a failure occurs during high-speed spin the door will be unlocked after 3 minuts. Check wireharness connections between the drive motor/Techometer and the motor control unit also check between the motor control unit and the central control unit. Check the drive motor, the motor control unit, and wire harness.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
Sep 14, 2009 | Kenmore Elite 45986 Front Load Washer
F06 Error Code
"F06" is a Motor Speed Error. The following link explains:
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Sep 11, 2009 | Kenmore Elite 45986 Front Load Washer
ERROR CODE F71
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool GHW9400L4
f06 is an error pertaining to the motor control board loacated behind the lower acess panel mounted in the left fron corner, first check for loose wire connection, sometimes alot of water/moisture will trip the control, remove and refit the wire harness leading to the control a few times and look for physiacal damage to board as well.
Nov 10, 2008 | Whirlpool GHW9400 Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
I'm getting a F06 error message.
f06 is a fault in the motor controller assy, located on the bottom left corner behingd the lower acess panel. check the wiring prior to rplacing the board though
Apr 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
439 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
