Question about HP Office Equipment & Supplies
Printer will not print when instructed by my computer.
    Problem Solver:
  • 7 Answers
Make sure your printer is installed. Click start. Click Printers and Faxes. Check that the default printer is you printer. Also check your manual to do a self test. This will check that your printer itself works and that the problem is really between your computer and printer. Hope this helps
Posted on Sep 15, 2008
How do you print to printer?
Hello, Terry -
You need to have the latest driver for your printer installed on your computer.
Plus, you need to have your printer connected to your computer, either by direct connection with a cable, or via WiFi connection.
The computer must be powered up and the printer power must be on. There must be adequate ink in the printer, and paper. Plus, if the connection is via WiFi, the computer must be connected to the Internet.
Once you have chosen the document, image, whatever to print from your computer, you should be able to follow the steps to print. I don't use a MacIntosh, so if you have a Mac, I cannot provide those steps for you. If you use Windows, once the document/whatever you wish to print is selected, click or tap on FILE (upper left of the window), click or tap on PRINT, and follow the on-screen steps.
I hope you have the instruction manual for your computer so you can read through it and follow the instructions for printing.
If you do not have the instruction manual for your computer, if you add the make and model of the printer in the Comment section, I may be able to locate the manual for you online.
Best wishes.
Feb 22, 2018 | PRINTER Office Equipment & Supplies
Why won't my printer print more than 1 Page at a time?
Please go to your printer preferences and select page setup choose default setting and customize other page setup then click apply and restart your PC. If not done then follow the instruction.
1. uninstall your present printer driver.
2. Restart your pc.
3. Install your printer driver again.
4. Restart your pc.
Hope it will solve it.
Thanks
Apr 07, 2016 | Epson Stylus Photo R3000 Inkjet Printer
Red light blinking
The Attention light is flashing red.
Solution The printer requires attention. Try the following:
* If the printer is connected to a computer, check the computer screen for
instructions.
* If you are printing a CD label on a CD/DVD, insert the CD/DVD holder in the
CD/DVD tray now.
* If you have a digital camera connected to the printer, check the camera screen
for instructions.
* If the printer is not connected to a computer, check for the following problems:
- Main cover open - Out of paper - Paper jam - Print carriage jammed or stuck - Print cartridge missing or inserted incorrectly - Print cartridge tape not removed - Incorrect print cartridge installed - Packaging materials are not removed * If you are unable to solve the problem by using the instructions above, turn off
the printer and unplug the printer power cord. Wait 10 seconds, and then plug
it in again. Turn on the printer.
Feb 18, 2014 | HP Photosmart D5160 InkJet Printer
My daughter was messing with the printer. When I print anything now, the printer prints out a thick black line covering everything where the text should be. Is there a way to re-set the printer to get it...
Disconnect the printer from the computer momentarily. Allow to lay idle for a while, then reconnect to power on the computer. A new allignment instructions will be requested from computer on attempt to print with new settings.
Jan 29, 2011 | Dell 946 All-In-One InkJet Printer
When printed document is sent to printer, it prints with dark lines below each line of print often obscuring every other line of print .
  1. When connected by a USB cable, reseat both ends of the cable going from the computer to the printer.
  2. When connected to a wired or wireless network, make sure the network is working correctly and that the printer is connected to the network.
  3. (to make sure the printer is on the network, print a network set up page, for more information on how refer to the user's guide, refer to the Downloading and Viewing Printer Manuals section for information on how to download and view the user's guide).
  4. Restart the computer.
  5. Turn the printer off.
  6. Unplug the printer power cord from the A/C outlet or surge protector and wait at least 30 seconds.
  7. Plug the printer power cord back into the A/C outlet or surge protector.
  8. Turn the printer back on.
  9. Make sure the desired printer is set as the default printer.
    • For instructions on how to check which printer is set as the default and change it if needed, Click Hereextlink.gif
  10. Print a test page.
    • For instructions on how to print a test page from Windows, Click Hereextlink.gif
  11. Run the automated printer fix available from Microsoft.
    • For instructions on how to run the automated printer fix available from Microsoft,
      Click Here
  12. Uninstall the printer driver, download and install the latest printer driver.
Nov 08, 2010 | Dell 948 All-In-One InkJet Printer
Printer not Printing
well this is the software issue till i can understand. to be sure that it is purely software issue try to copy from your printer itself and see if that is not the printer's fault.
if its not then:
Remove printer's USB cable from your computer
delete the Printer's Icon from your control panel/ system preferences> Printers and faxes/ printers
now uninstall the software of kodak and reinstall the the software from www.kodak.com/go/esp3downloads
after software installs then plug your printer back in and wait untill it get installed on your system
try to print it again and see if you can print
May 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
● If the printer is connected to a computer, check the computer screen for
instructions. If the printer is not connected to a computer, check for the following
problems:
– Top cover open
– Out of paper
– Paper jam
– Print carriage jammed or stuck
– Print cartridge inserted incorrectly
– Incorrect print cartridge installed
● If you are unable to solve the problem by using the instructions above, turn off the
printer and unplug the printer's power cord. Wait one minute, then plug it in again.
Sep 29, 2009 | HP Photosmart 7450 InkJet Printer
I have a samsung scx4300 connected as a network printer. It will print from the computer it is directly connected to but not from the network. Can anyone help
Click start, click control panel, click printer and fax, right click the printer icon click printer sharing and follow the computer instruction till it finish. Go to the other PC click start, control panel, printer and fax click add printer, and follow the computer instruction except for the computer will as to locate printer click the network printer and the printer will appear click the printer this will add to the PC. now you can print to that PC. Hope this will help you.
HH
Aug 12, 2009 | Samsung SCX-4300 Monochrome Laser...
Printer goes through the motions but text does not print
Let's first test the printer independant of your computer:
Try printing a test page using the instructions here: http://www.ehow.com/how_2006016_perform-test-epson.html. I hope your model printer is listed there. If not, try to find instructions specific to your model in your model's user guide or elsewhere on the internet.
If this works and printing from your computer doesn't, then:
(???Bad print drivers???) Reload the print drivers on your computer.
(???Bad cable???) Try replacing the printer/USB cable that connects this printer to your computer.
(???Bad USB port???) Try using a different port to connect the cable to your computer.
If none of this works you either have a faulty ink cartridge or a more serious issue with the printer. Depending upon the model, unfortunately, it might be cheaper to replace than repair.
May 28, 2009 | Epson Office Equipment & Supplies
CX3810 printer will not print
Take out the cartridges from the printer, put them back.
Remove the printer completely from your computer. Reboot. Re-install the printer.
Try to print again.
It sounds like your print heads are shot.
Nov 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
