HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the AVery Label paper I put in the paper tray. And I don't know how to manually feed it! The icon of the printer says: "No Paper Fed Manual Slot" Now what?
Try this link http://www.retrevo.com/r/23555ci953/24/Printing+on+thick+paper,+labels+and+envelopes#q=Brother+HL-2140
the manual paper feed slot is at the front of your printer, under the 'Brother' sign. Be sure to open the back flap of the printer too (to let the labels come out)
Posted on Feb 20, 2010
  • 75 Answers
Pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Posted on Sep 15, 2008
  • Zafar Hussain
    Zafar Hussain Dec 18, 2013
    That an extremely stupid answer NOOOOB
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
Error light is flashing red
check if the paper tray is empty.
or if you didn't check you printer before
http://www.ehow.com/how_6764715_troubleshoot-2140-compact-laser-printer.html
Feb 04, 2011 | Brother HL 2140 Laser Printer
I amusing a Brother HL-2140. Recently, the paper curls up and gets stuck in the tray, and will not move forward. I have cleared the pat several times, but the paper is stuck in the rollers, and it tears...
Turn off the machine, > Open the front cover > remove the drum, cartridges, > and check if you can see the jammed paper or not, if so pull it out slowly. If you can't see the paper, close the front cover > Pull out the Tray completely > and once again check if you can see it or not, if so pull it out. Still it's not there? then install the tray and open the back door > pull the tab to open the fuser unit and pull out the paper, you can also pull out the fuser unit.
You can also refer to this tutorial from Brother Solution center..how to clear paper jam
Good luck.
Thanks for using FixYa.
Aug 13, 2010 | Brother HL 2140 Laser Printer
Connected to printer via USB cable, worked in the past, now it just doesn't print -says 'error'
If the error light is flashing it means that Either there is a paper jam in the machine or the back or front cover is open.
If the error light is ON, it means that there is no paper in tray one or manual tray. Some times from certain programs it will ask the printer for the manual tray because it feels that the margins are too big.
Try putting a piece of paper in the manual feed slot above the paper tray.
Mar 28, 2010 | Brother HL 2140 Laser Printer
For the HL-2140 Brother printer, the red error
Too many things can cause that, you remove the drum and run the blue tab back and forth to clean the corona about 20 times, the fuser may not be heating and you need a new fuser, Feel for heat in the back door or at the exit, If the drum is used up you open the front door and press go until the lights flash to reset. Make sure the paper tray is fully inserted, this one is picky. You may need a shop to diagnose.
Feb 01, 2010 | Office Equipment & Supplies
Red Error light is on, what is this error and how to get out of it?
If the light is steady (not flashing), it means a paper problem. Either the paper tray is empty, or maybe the document you're trying to print is set to 'manual feed.' If the latter, then modify the page setup in properties, to use the defult paper tray.
Oct 06, 2009 | Brother HL 2140 Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Some paper got jammed, so I took it out. Now the
hi, Hello... I would like to try my hand at your problem (it sounds familiar and might be solvable). In a case like this, one has to treat a persistent paper jam assiduously: 1. Turn off the printer, and unplug it. Open up the printer completely, by all available hatches etc (-being that it's a laser printer, mind that too much exposure to bright light will spoil the bluish-reddish developer drum, so don't let light onto it more than a minute or so... or less preferably.) 2. Examine the path the paper takes, as it is printed, from the beginning (the paper tray, or sheet feeder, or manual feeder) to the end (the output tray), and all points in between. 3. Wherever there are bits of paper, or fluff, or anything like that, get it out of there! (-and of course, don't touch the drum - but you know that aleady.) 4. If there are any mechanical sensor switches, make sure they are not bent out of position or otherwise 'stuck on'... and if there are any optical sensors you can see, be extra sure there is nothing sticking in them (within the squared-off-U-shape most of them look like that), that would activate them. 5. Can't see anything? Reset your printer, as follows: Turn the printer OFF. (Or if it won't turn off, just) Unplug the printer from the wall or power strip. Leave it that way for 10 minutes. Plug it back in. Turn it on if it didn't turn itself on. Wait for it to initialize. Try printing again.
Jun 09, 2009 | Brother HL 2140 Laser Printer
BROTHER PRINTER HL-2140
Try turning the printer off and back on. if this doesn't help, open any cover that will open and look for paper still in the printer. many times, if you stop the printer mid-job, paper will be stuck in the back of them, and most printers will not recover until you remove the paper jam.
Feb 10, 2009 | Brother HL-2040 Laser Printer
Computers & Internet Logo
524 people viewed this question
Alun Cox
David Payne
David Payne
