Microsoft Zune JS8-00001 Digital Media Player Logo
Posted on Sep 15, 2008
Zune how do you do a master reset- as in everything off, restore factory setting, on an 80 gb zune?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
220
Points
Hold back and up when it starts to reset hold these 3 buttons back, left on key pad and middle it shouls reset the whole thing delete everything
ZTE projector needs a factory reset how can I fix this problem
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Device resets ZTE ZMAX
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Hope this helps!
Reset zte maxx
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
2helpful
2answers
What is master reset all about? can i have an explanation?
To make it simple, A master reset restores your phone to default factory settings wiping off data from it...
5helpful
2answers
Master reset motorola blur
Please note: All phone data will be deleted. Data on the SIM card is not deleted. Restore the factory default settings
  • Press the menu icon.
  • Press Settings.
  • Press Privacy.
  • Press Factory data reset.
  • Press Reset phone.
  • Press Erase everything.
  • Wait a moment while the phone restores the factory default settings.
  • Follow the instructions on the display to configure the phone and prepare it for use.
1helpful
4answers
To restore the factory setting
how to restor k300i factory settings
Mar 10, 2011 • Cell Phones
4helpful
2answers
I want to start over with my Zune Model 1089. I want to clear everything off of it and start over. Please help....
1. Slide the "hold" switch so that it is in the unlocked position. 2. Press the "Back" button and the top of the Zune pad at the same time and hold until the device resets and begins to power up. Release the buttons when the Zune starts to power on. 3. Immediately press and hold the "Back" button and both the left side and the center of the Zune pad and continue to hold until the Zune restarts. The phrase "Please Wait" will appear on the LCD screen. Release the buttons.
4.Let the Zune continue resetting. It will clear the contents and eventually display "Connect Zune to your PC" when it is ready.
5. Connect the Zune to your PC via the sync cable. Follow the prompts given by the Zune software to completely restore the Zune device to the factory settings. If you have downloaded newer Zune firmware, you have the option to restore the Zune firmware with the latest version.
Zune 80 gb please help me ;)
your videos should already be in there. check what folder there in and move them to your videos folder. try clicking the arrow buttons and then up on the key pad to restore it. and check to see if it works then..
20helpful
8answers
Zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Top Microsoft Audio Players & Recorders Experts
john h
Vinho Xie
Vinho Xie
Rick Rock
Rick Rock
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
