Question about Garmin GPS
"On/off" button does not work on Garmin Nuvi 350. Can onlt yurn unit on by placing in car mount, connected to 12-v DC outlet. Unable to use unit outside auto...otherwise works fine.
  • nampahc Sep 15, 2008
    Thank you for diagnosing my problem and explaining its origin. I have sent a private email with a request for a contact for repairs in my area.
    nampahc
  • Garmin Master
  • 2,130 Answers
Please read my article on this problem. I have repaired many Nuvi's with this issue. Please email me at ks3r at sharc dot net and I'll be happy to discuss the matter further with you. I have references.
http://www.fixya.com/support/r953225-garmin_nuvi_350_off_power_switch_problem
- Jim
Posted on Sep 15, 2008
  • SHARCNET-USA
    SHARCNET-USA Sep 15, 2008
    You're welcome. I received it and replied. :)
Garmin nuvi 745
Yes, a Cellphone, Google Maps and a Power Block will give you about 5 days use!
You could also carry a small 12 volt lithium battery of the type used in alarms in a back pack, connected to a cigar lighter like this unit.
12VOLT RECHARGEABLE PORTABLE BATTERY POWER PACK 12V DC CHARGER LIGHTER...
Or this
Lightweight 12 volt portable battery station Lithium ion 8 8 Amp Hours...
Or you buy a GPS Sat Nave unit specially made for cycles.
Cycling GPS Units Amazon co uk
Garmin Edge 1030
Garmin Edge 1030 GPS black 2018 handheld colour gps
Nov 18, 2017 | GPS
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
How do I connect the garmin nuvu to portable friction mount
Hello.
The Garmin Nuvi GPS unit can be taken on the go or set up inyour vehicle. Most units come with a window suction mount that attachesdirectly to your window while some have a sticky dashboard mount. These twooptions can leave permanent marks on your car, with a dark circle on yourwindow or leftover adhesive on your dashboard. Use a friction mount to avoiddamaging your car. The mount uses bean bags to hold it in place withoutdamaging the dashboard.
Instructions
1 Place the friction mount bean bag on the center ofyour dashboard. 2 Snap the Nuvi unit into the plastic mount and set iton top of the bean bag mount. 3 Position the Nuvi at the angle you prefer for bestvisibility while driving. 4 Hold the mount in position and slide the switch tothe "Lock" position. 5 Connect the cables to the Nuvi and you are done.
Thanks for using fixya.
Sep 06, 2011 | Garmin GPS
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
http://www.sharc.net/gps_charger_repair.htm
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi 350 does not aquire sattalites?
Make sure it is in its mount. The antenna is in the mount and needs to be connected tight also make sure You have a view of the sky and not parked in a garage that blocks the signal
Oct 28, 2009 | Garmin Nuvi 350 Car GPS Receiver
When i plug in my garmin to a car charger it
u need to replace the battery, they last about 2 years on average.
Sep 10, 2009 | Garmin nuvi 350 GPS Receiver
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Traffic Receiver connection
You have to power the unit via the mount by either using the cigar charger in the car or snap off the mount from the ball and socket and power it via the mains adapter.
Jan 02, 2008 | Garmin GTM 12 FM TMC Traffic Receiver...
Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Nov 10, 2007 | Garmin nuvi 350 GPS Receiver
Power button don't work
Likely a mechanical failure of the power switch. I called Garmin, described the problem, got an RMA number, mailed in my 350, and received a refurbished unit in less than 1 week.
Jul 09, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
