Question about LG Televison & Video
I have an LG LCD TV (42LC2D) & a LG HDD/DVD Recorder (DBRH197). The HDD/DVD is connected to the TV via a HDMI cable. Generally, when I watch DVDs, I change the Input on the TV to HDMI, however since last night, when I do this, I am getting an on-screen message of "No Signal" and "Invalid Format". I have tried to reset the HDD/DVD by following the instructions on Pg 61 of the Owners Manual, but to no avail. Please advise how to fix the problem. As a family of European background, my husband & I want to be able to watch DVDs from all Regions, not just Region 4.
  • 6,487 Answers
First thing to do here is to check the connection adn if possible try a different cable , because sometimes this can only be a connection or a cable problem,, as for making it unlock so you can watch any DVD on it, there's a lot of site there that is offering that service to unlock the regional code of this unit...
Hope that helps.........
Posted on Sep 15, 2008
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
How can i improve my tv LG LH20 42" in terms of
There are a couple of things that you can try to see if the image clears up, or is to your liking. You can adjust the resolution of the picture via the menu in the tv. You can also try resetting the tv to the factory settings, via the menu. You can also try auto configuration, which is also a menu item. If you are using a dvd/blu-ray player, use the HDMI cable for optimum picture quality.
Mar 08, 2011 | LG 42LC2D 42 in. LCD HDTV
Use an HDMI cable from my LG DVB-T HDD/DVD recorder
A quick google search of that model number turns up that tv doesn't have an HDMI port. Your next option would just use component cables instead. At 26 inches you will never notice the difference.
Dec 23, 2009 | Philips 26PF9956 26 in. Television
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Can't remove AV Input display
Try setting hdmi control to off in tv menu
Apr 06, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
DBRH197
It only has a standard definition stb in it, the unit doesnt support high def. sorry, ****-face
Jan 11, 2008 | LG DBRH197H DVD Player/HDD Recorder
Televison & Video Logo
329 people viewed this question
Computer Repairing
Computer Repairing
