Question about Panasonic DMR-E85H DVD Recorder
Cannot download TV Guide schedule-Verizon FIOS
Problem with Panasonic DMR-E85H/FIOS trying to download TV guide schedule from Motorola QIP6200
I have repeatedly tried to download the TV guide schedule and have not had any luck. IR is set up correctly. When I turn off the DVD-Recorder it appears that it is trying to read the schedule from the Motorola box (in other words I see the channels changing on the cable box).
I am able to set up manual date/time for recordings but it sure would be nice to be able to use the TV guide schedule.
Any help or recommendations would be very much appreciated.
    Sergeant:
  • 241 Answers
I would suggest you follow this in the order i gave you Ok
Leave the unit turned off until the unit downloads the television
program list. This may take up to a maximum of 24 hours.
  • When the unit is connected to a cable TV box, the cable TV box
must be turned on in order to download the television program
list.
  • When the unit is connected to a cable TV box, note that the
television program list may not be downloaded correctly if you
change the channel of the cable TV box while the unit is turned
off.
If you find “There is no data for this screen” on the television when
you turn the unit on, the unit has not yet downloaded the program list
Thak you
jayson
Posted on Sep 15, 2008
  • 1 more comment
  • Jayson Brollini
    Jayson Brollini Sep 15, 2008
    I just want to add to my first comment as well
    • The unit downloads the television program list only when the unit is turned off.
    • When the unit is connected to a cable TV box, the cable TVbox must be turned on in order to download the television program list.
  • Jayson Brollini
    If you have followed all the steps then please
    double check the following "I have a similar model and it was frustrating but it works now"
    • Cable TV box connection channel (Ch2/Ch3/Ch4/L3 )
    • If you are connecting the cable TV box to this unit’s L3 terminal, select “L3”.
    • If you are connecting the cable TV box to this unit’s RF terminal,select ( “Ch2”, “Ch3” or “Ch4”), according to the cable TV box setting.
  • Jayson Brollini
    If you need futher steps to follow please post
    FixYa Expert
    Jayson
  • 6,487 Answers
With this problem I will suggest you to contact Verizon or motorola so they can help you better with this concern this is the number 1-877-466-8646....
Hope that helps.........
How to get an user guide for panasonic dmr-e85h dvd recorder
You can get the manual on the link below.
http://service.us.panasonic.com/opermanpdf/dmre85h.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 31, 2010 | Panasonic DMR-E85H DVD Recorder
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
I can't get the recorder to keep my guide.
There might be a TV Guide issue located in your area, since the transition to digital, TV Guide have been updating there broadcast frequency which is know been done by CBS. Have unit reset by holding down channel up and down button for 15 second on the unit itself until 12 flashes on display, then power on unit and setup TV Guide, then have unit off for 24 hours especially between 11pm to 6am for listing. If issue still exist contact Panasonic to have issue send to TV Guide.
Sep 28, 2009 | Panasonic DMR-E85H DVD Recorder
No sound from my DMR-ES40 Panasonic dvd recorder.
Make sure the scart lead is fully in on the tv and the dvd,this can cause pic no sound or sound no pic
Aug 30, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Won't allow manual clock set - tv guide not loading
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
will self check, say test L1, power off, on again.. go thru setup. no data was lost.
Apr 04, 2009 | Panasonic DMR-E85H DVD Recorder
Cannot get E85H to boot - U99 error
I downloaded and installed the firmware upgrade from 2005 (my machine was bought in 04) - after that it is now working fine!
Dec 15, 2008 | Panasonic DMR-E85H DVD Recorder
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
DMR-E85h
That's frustrating huh! I finally found someone at the cable company that knew somthing.. I think it's channel 95 (might be 94), if you tune to that channel, sometimes it get's it immediately, other times it needs some time to download it. But make sure you're tuning to that channel in your line up. In the setup mode you can specify it if it doesn't do it automatically. (just spend some time in setup and you'll see what I mean)
Nov 14, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
278 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
