Question about Sentry Fireproof Safe
Sentry s3877 battery compartment broke
I have a model s3387. The plastic battery compartment that holds the 4 AA batteries broke. I am able to hold it together good enough to get the safe opened. I would like to buy a new battery compartment and cut the wires to the broken one and wire in the new one. Any idea where I can buy a replacement battery compartment???
Thanks
  • Anonymous Sep 15, 2008
    DAIVED OoOoO
I had the same problem with my Sentry S3877. I found the exact 4-battery replacement (with snap attachment on top!) at an online electronics.retailer, but had to purchase a lot of three. I don't need the other two, so I'll sell them for just $6 each to the first two folks to contact me mark@irregardless.net.
Oh, by the way, once the batteries went dead, you lost your combination! When you pop the new battery compartment in, the factory default combination will be in effect. That default combination is in your user's manual. I'm currently searching frantically for mine! Gee, how could I have misplaced it ... I just had it in my hands when I purchased the safe 10 years ago !!!
Anyone know the default combo for the S3877?
---- Mark
Posted on Nov 14, 2008
GEB DCVTGB WFBG
SGBCVV SVB
FZXVA XCDC
Posted on Sep 15, 2008
How do I get my Sentry Safe S3877 to open when one of the wire is dangling from the battery pack?
Check, you are connecting to the correct spot. That is the place the wire broke off.
It could be you only are using 2 or 3 from the four batteries. Then the voltage is always to low.
Then check you got the right batteries. Never use manganese (Zinc-Carbon) batteries. They don't have enough capacity and can start leaking.
Sep 27, 2014 | Horace Small HS2148 Mens Sentry Plus...
Sentry safe reset instructions
You can get help here, but you will need to prove ownership... http://www.sentrysafe.com/CustomerCare/
Jul 14, 2014 | Home Security
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
Dec 07, 2010 | Sentry Fireproof Safe
Somehow can open my sentry s3877 with the keypad.
A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
Jan 07, 2010 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Battery connectors broke
Hey there NewYork691,
I'm from Long Island. The name is Mike and I may be able to give you a more economical solution.
From your description, it sounds like one of the contact that connect the (+) of one battery to the (-) of the next battery broke. If that's what happened, no worries, you'll be fixed in no time.
Find yourself a penlight, remote or any other device that uses AA batteries that you aren't going to miss. Open up the battery compartment and remove one of the spring contacts.
You may have to hunt around to find something similar, but all it has to do is fit in and make contact. The compartment cover will hold the batteries in.
You should be back in business.
Mike
Dec 06, 2008 | Futaba Toys
Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Sep 29, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,180 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
