Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I need help in opening my Ultimate Care II washer's housing
I've a direct drive washer from Whirlpool. I now noticed that water is dripping from the tub too. I want to open the panel and housing, but not sure how. Does anyone has a repair video or some instructions to open this washer. The model number is LSB3600PW.
thanx much
  • NoviceTinker Sep 17, 2008
    I forgot to update this earlier. But yesterday I found a site that had listed step by step instructions with photos on how to open the cabinet. I did it and then realized that the leakage was coming from the pump which I thought I had fixed earlier last week by putting some kwikseal glue. Apparently, it did not seal properly. So I removed the pump, put some superglue and duct tape over the leaking point and lo and behold the leaking stopped. So, even though I opened the cabinet, I did not have to. But "Prayers" comments were right on the mark, and I appreciate it very much.
    thank you
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Two screws on top usually on front take out flip up top you will see two gold clips on each side.take a flat tip screw driver put them in slots and pop loose remove unplug spin switch and lean cabinet forward and slide off .leak could be coming from pump tilt back first look inder it have a paint can or coffe can or tilt it way back and look under it pump on motor is probably leaking then take off case
Posted on Sep 16, 2008
  • PRAYERS Sep 17, 2008
    your very welcome glad to be of help
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirpool Ultimate Care II washer - drips
    Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
    If that does not solve the leak through problem,the water inlet valve will have to be replaced.
    Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
    http://appliancejunk.com/forums/index.php?topic=5191.0
    Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Water leaked from bottom of washer
    Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
    Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer is Leaking Water
    Replace pump. The newer ones are a little thicker. Hair and sand will cause them to fail, like bath mats and door mats.
    Apr 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care 2 leak after wash cycle
    Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
    Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    I can't find the model number on washer Whirlpool Ultimate Care
    Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
    Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    83 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
