I INSTALLED MY ATI RAEDEON 128PCI VIDEO CARD AND IT HAS S VIDEO OUT AND COMES WITH THE SVIDEO TO RCA CABLE BUT I CANT GET THE IMAGE TO DISPLAY ON TV
    Sergeant:
  • 300 Answers
The S-video to Composit adaptor tells me that you wish to connect to the Composit input of the TV
Connect the TV , set the TV to ( Composit input ) Composit 1 , or Composit 2 , NOT A CHANNEL
restart the computer , this will help the video card and software to detect that the TV is now on and connected.
When you come back to windows you should be prompted to perform the television setup wizard
if not
go to your display properties
Advanced tab
and manualy configure the video card for television output.
Selah.
Posted on Sep 15, 2008
Trying to connect svideo out to a tv but don't seem to have an output.
You don't have an output on your video card? Or you don't have an input on your tv? If you don't have an input on your tv you can use an s-video to rca adapter like the one here:
http://www.google.com/products....
Thank you,
Lee
Feb 13, 2011 | VisionTek ATI RADEON HD2400 Pro Edition...
What channel do i go to for svideo cable??
The TV doesn't output the TV as such, UNLESS it has what is called a "Monitor" Output Sockets on it. Then you can connect up to, say another "Screen" or Take the Outgoing Video, & Sound, and "Record" it to a PC, via a Video INPUT via a TV/Video INPUT card. BUT you cannot play the TV on the laptop, FROM the TV. like you wish to do. If your laptop has a TV card INSIDE your laptop, then you could use that and display the OUTPUT from that TV cards' tuner, on the TV. But not the "other" way around. That SVHS is ONLY an INPUT out from your PC. You can put you system into either "Cloned"mode, IE: Whats displayed on laptop screen,is also displayed on the TV, Or, you can have as you seem to now, Extended Desktop. I hope this clears things up for you. Also when using that SVHS connection the Audio comes OUT on the Red & White AV sockets on the set. So you need that cable and another pair for the Audio..
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
Want to hook up old tv model ds32224 to my pc
Hi there
To answer your question;
First on your pc you will need a video card that has either composite or svideo output.
Then you`ll need a single rca cable or svideo cable to go from pc video out to tv video in.
If you want the sound going through the tv as well, you will need a stereo audio cable with 1/8" phone jack at one end and two rca connectors at the other end.
The audio will go from the sound card out to audio in on the tv
Hope this help. Happy Holiday
Dec 28, 2009 | Televison & Video
Watching television on Philips Freevents MT2700
Did it come with Windows Media Center?
You will need a TV Tuner to watch TV. There are internal cards or USB types.
Mar 20, 2009 | Computers & Internet
Computer TV out with S Video
You can use the yellow RCA cable using an SVideo adaptor. When using dual displays make sure that display number 2 is adtive. To do that move the mouse to display 2 press the right mouse button and select active. Check extend desktop to the monitor to check the signal and press apply. Make sure you are using either an Svideo or RCA signal.
Sep 02, 2008 | RCA RT2380 System
Im getting black and white picture from my s-video output
Possibly you have a 2 channel av card built on your tv have you checked all channels if so Maplins do a s-video to phono adapter that converts to colour
May 22, 2008 | Computers & Internet
C640 sVideo problem
you definitely need to get the drivedr for the svideo option. it wil actually not show you in the device manager the svideo, but the graphics card details only. to find out if you have a secondary display (svideo) you have to go to your display properties then and see if you have dual display. try to bott also your dell with the svideo-tv already connected and see if you get a post display on your tv. now... i need to know only if your svideo is active, drivers will still be need to get the windows work there.
May 03, 2008 | Dell Latitude C640 Notebook
Ati mobility radeon 9000 agp
hi camperd55,
I believe you have the right adapter cable. According to my knowledge the Radeon 9000 supports TV output via RCA (check http://ati.amd.com/products/MobilityRadeon9000/index.html:" Mobility™ Radeon™ 9000 provides the highest quality output support for DVI-I, TV and CRTs.")
Firstly, it would be a good idea to make sure your TV has the 3 RCA jacks into which you will insert the adapter cable's 3 RCA connectors according to the colors of the connectors and jacks.
Secondly, if your laptop has a VGA port, you're set to connect your laptop to your TV, no hustles. If your laptop doesn't have a VGA port, your going to have to get a DVI-VGA converter, so you're setup will be something like: [laptop]-[DVI-VGA converter]-[VGA-3RCA adapter cable]-[TV's 3RCA jacks].
When you get your laptop's screen displaying on your TV, its merely a matter of using your recording equipment to record the TV's image as you would any program showing on the TV.
I hope this will help you solve your problem, thank you for using the FixYa service.
Kind regards
Henru : )
kind regards
Feb 10, 2008 | ATI Mobility RADEON Graphic Card
Trying to connect Inspiron 6000 to TV
If there is no display on your TV, HDTV, or Projector, please make sure that all of your connections are set up properly and that you have enabled the display in the Catalyst Control Center. The connectors that you will be using would be Svideo for TVOUT, DVI-to-HDTV (Component video), VGA-to-HDTV (Component video) for HDTV, and DVI, VGA, or Svideo for the projector.
737-22474-1.jpg Here are the steps to properly setup and enable TV, HDTV, or Projector:
  • Turn off your PC and your TV, HDTV, or Projector.
  • Ensure that your card was installed correctly, as per the Getting Started Guide.
  • Determine if your TV, HDTV, or Projector has a S-Video (for TV), YPbPr for (HDTV), or VGA/DVI for Projector.
  • Looking at the back of your PC, locate the needed connector or the supplied adapter cable; attach one end of the cable to your graphics card and the other to your second display.
  • Turn on your second display then your PC.
If you are connecting an HDTV to your video card, please Click here for detailed instructions on how to set it up correctly.
Starting Windows with TV or Projector Display Enabled The TV screen may become scrambled during the initial Windows® logo display. This is only a temporary effect and your screen will be restored within a few seconds. During start up, your RADEON will go through a sequence of mode settings, during which your TV display will remain blank. This process takes only a few seconds and helps program the TV display.
  • To enable the second Display
  • Right-click anywhere on your desktop
  • Click Catalyst Control center
  • View
  • Advanced view
  • Display manager
  • Detect Displays
  • You should have the second display picture under “Attached displays currently disabled
  • Drag it to the box on top of it
  • Apply
  • OK
If for any reason the second display does not get detected, please do the following:
  • Open the CATALYST CONTROL CENTER
  • Go to Display options
  • Check “Force TV detection” *
  • Apply
  • OK
* Force TV: Allows you to force TV detection if the ATI driver does not automatically detect TV-out connected to the graphics accelerator.
Possible issues:
In case the users display does not natively support HDTV display timings in the EDID, you can add standard HDTV modes so that the usual HDTV resolutions (720p, 1080i, 1080p) are listed in the Display Manager resolutions. You can also create custom HDTV timings to solve any kind of over-scan options (for cases when the windows desktop appears to not fit on the HDTV screen, and the outside boarder is cut off).
For more information on connecting your second display to your Video card, including supported output device combinations, please refer to your user’s manual.
Jan 23, 2008 | Dell Inspiron 6000 Notebook
No color when switching to component cable
To Change DVD Player Video Output to Progressive Scan: With your DVD Player turned on, and your TV turned on, press and hold the PREV/VIDEO button for at least 3 seconds (this puts you into Video Output mode). Press the PREV/VIDEO button to access different video output options. Each time you press
PREV/VIDEO, the type of video being displayed appears next to the Display menu. Look for PSCAN on your DVD player display panel. At this time, your progressive scan on TV should be working.
Oct 18, 2007 | RCA DRC233N DVD Player
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
