Question about Polaroid FLM-2601 Television
White screen my screen is white when i turn it on and it seems that i have to let it run for a little bit like its warming up. after a while it works but it takes longer for it to work. Now it turns on the the white screen and turns itself off 5 seconds later
Its broken, and i dont think there is any fixing it, im getting a new one
Posted on Sep 16, 2008
Have a 94 Camaro smokes white first start it and its raining after it warms up or I run it a lil bit it quits smoken. It runs good and don't seem to have any other problems
Sounds like your head gasket is cracked letting radiator fluid into your pistons. After it runs a little bit the water will dissipate. White smoke means you are getting water into the piston areas. Better repair ASAP before major damage is done. Will cost you big time if you don;t get repaired.
Apr 21, 2015 | 1994 Chevrolet Camaro
Wont turn over
Was it coolant that sprayed out somewhere? Have you checked and located the leak? If coolant sprayed all over the engine compartment, probably made it's way under the distributor cap. If water get in there, engine will turn over but never start. Try removing the distributor cap and spraying WD40 all over the inside of the cap and rotor. WD stands for Water Displacement, old trick but still works great .
Mar 26, 2014 | 2000 GMC Jimmy
Screen freezes
the electronics are failing after it has got warm. Replace the TV.
Dec 15, 2013 | Dynex DX-19L150A11 720p 60Hz 19in Flat...
Idle is high at start - 1800 rpm. Seems like excessive white smoke from exhaust. Put into reverse and back out of driveway it has a regular shudder (bump bump bump) but not hard metal grinding sound.....
white smoke out of the exhaust would be a sign that it is burning coolant... if it goes away after it warms up, it could just be condensation inside the exhaust pipe. 1800 rpm is a very high idle, maybe have your IAC motor on the throttle body checked... check engine light? if so have the code read at your local auto zone.
Aug 09, 2011 | 1998 Toyota 4Runner
Avic-d2 question
sometimes i notice the touch screen calibration is a little bit off...Try to push the okay button a little bit to the left or right working your way from the okay button to the edge of the screen
Jun 07, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Noise from engine
Does the noise come from the engine or transmission, Pull the dipstick tube from the transmission when it is warm and smell it for a burnt smell.Check oil dipstick for any water or white paste.
Feb 05, 2010 | 2002 Jeep Grand Cherokee
My ipod nano has a white screen
Try this - it at least seems to have fixed the same problem, at least for now, with my 2nd generation Nano:
1. When you see the white screen, hold down both the Play and Select buttons together, pressing the Play button a little bit before the Select button.
2. When the white screen goes to black, release the two buttons almost simultaneously with the Select button released slightly before the Play button.
3. Hopefully, if done with the right timing, you should get your normal screen back. If not, try switching the Hold on and off or changing the starting mode by listening through headphones to see if it is playing or not.
4. Once you have recovered the screen, plug it into your computer to sync without turning it off and perform a complete sync. After I did this my Nano stayed in the normal screen mode. Before I had done this step, it kept reverting to the white screen.
One more thing to try if this still doesn't work is to first try restoring the Nano completely through iTunes.
I'll be interested to hear whether my solution works for anyone else.
Sep 16, 2008 | Apple iPod nano
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Polaroid FLM-2601 Television Logo
147 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
