Question about Dell PART NUMBER KIT SPEAKER MM ACS45 ALTEC EUR 45502 Computer Speakers
Altec Lansing ACS45.2-Lightning strike
We had a lightning strike near the house that I think came in through the cable. The cable amplifier was fried along with a wireless router and one TV will not turn on. I was using this subwoofer on my main TV that did not get damaged. The trouble is that I can no longer turn the subwoofer on by pressing the two volume buttons. The main fuse in the unit is good and I am getting about 18.7 volts DC after the diodes. Nothing looks cooked. Is there anyway to just install an on/off switch somewhere? Thanks
  • jdob28 Sep 15, 2008
    After more research on the web I found someone that had the same problem (would not turn on after static shock). He found it to be the volume control IC. He talked about the volume control pins should have a voltage of 12 and his where 1.2 (the same as mine) so I am ordered a new IC. I'll let you know if it works. Thanks for the quick response.
  • stingzcool May 11, 2010
    Did installing the new IC fix your problem?
    Brigadier General:
  • 5,158 Answers
There is a good chance with a lightening strike that damaged so much of your equipment that this device was also affected. power to the device doesn't necessarily mean that other components were not damaged.... you can elimanate speaker damage by hooking the speakers up to another device to check them.
Robert
Posted on Sep 15, 2008
Is there an adapter/cord (30 Pin to Lightning, or 30 Pin to Bluetooth) actually KNOWN to work with the Altec Lansing iMT800, so we can all charge and control the newer Lightning connector style iPhone
I think your only option is to get one sold in Apple stores. I have a small 30-pin-to-Lightning adapter (not a cable) and it does not work with either my iPad mini or my wife's iPhone 5. I also have a non-Apple Lightning charging cable (as a backup, just in case...). Same deal.
Dec 16, 2014 | Altec Lansing inMotion MIX iMT800 Portable...
Power connector cable for this unit, where can I buy one
hi were can i buy a power connector cable. a lightning audio s4.300 im in new zealand auckland 02102644759
May 03, 2013 | Lightning Audio S4.300 Strike Car Audio...
Bosch dishwasher does not turn on following a lightning strike near the house last night
Check your circuit breaker first. If ok suspect control board got fried. If you take it out you may see a burnt spot on it.
Sep 25, 2011 | Bosch Dishwashers
When i connect the lan wire my mother board shows lan not connected why/
Either the cable is defective (it has a break inside it so try another one) or the onboard LAN chip was fried by the power surge generated by a lightning strike that came in your vicinity.
That is unfixable, disable the onboard one from the BIOS and install a simple PCI LAN card in its place.
Aug 17, 2011 | Intel D945GCCR Motherboard
Will not heat baby food for 13 seconds
Depending on the amount of Joules your household/microwave received your low voltage control electronics may have been fried by the lightning strike. For your own safety I recommend a new microwave.
Jun 10, 2010 | Maytag MMV5186A Microwave Oven
POWER SURGE
sounds like DC on that output.
needs service possibly fried all the output transistors on that channel
Jul 30, 2008 | Xantech PA1235X Amplifier
Lightning
In a nutshell, yes and not only to a Dell but to most computer brands/models. In some instances, it's only the modem, router, LAN card that gets fried while some gets everything toasted.
Incidentally, even a near lightning strike is enough to cause big problems.
Kind regards.
Dec 12, 2007 | Dell Dimension 2400 PC Desktop
765 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
