Question about Bissell Vacuums
I have a bissell 6579 and the handle release pedal is not working properly
Agent Don
  • 310 Answers
SOURCE: how do i take off
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=539036
Generic problem for all Vacuums
How do i take off
Posted by retthom on Apr 23, 2008
How do i take off the handle release pedal on a Bissell
model 8990 cleanview bagless sweeper so i can fix it
ret1@tampabayrr.com
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Mostly, you need to remove the top cover to the Bissell in order to get @ the handle release pedal. There could be screws on the bottom 2 or 3 screws or the top cover could be held on plastic clips or levers and they would have to be released then the top cover would come off.
This should expose the handle release pedal. If you need more information please feel free to contact your local vacuum cleaner dealer in your area in the yellow pages, or use the trouble shooting guide in the owner’s manual or you can call the Bissell factory @ the information listed below:
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 23, 2008
  • 107 Answers
SOURCE: Bissel 3593Handle Release Lever/Pedall replacement
You need to replace slider release not just the handle. Take off the screws holding the black plate under the removavle canister the you will be able to see the slide release.
Posted on Dec 08, 2008
SOURCE: bissell 3595 handle release pedal spring(?) missing
I just fixed this on my Bissell PowerForce model #6594 vacuum myself. Woo Hoo for me. :-)
I called the local vacuum repair guy and he told me he'd repair it for me if I insisted but that since my machine only cost about $80 (a lot of money for me) it would not be worth the $40-$50 repair. I should just buy a new vacuum (from him I assume).
My machine works great so I sat down on the floor and after removing 5 screws and a little tinkering I got my machine apart. I had to take the brush and belt area off and then the upright part came off the base. Make sure you unplug your unit before working on it.
Next I could see where the Handle Release Pedal (HRP) on the bottom of the unit had been cracked. It's a molded piece that has a slight curve in it that allows it to spring back into position to hold the vacuum in the upright position or to keep the vacuum from going totally flat.
How it was installed I don't think they meant for it to be easily replaced but after using a screw driver on one side and a letter opener on the skinnier side I pried the molded houseing out from around the HRP just enough to let the it release. I did need a third hand for that part.
Posted on Jul 31, 2009
SOURCE: bissell 6579-2 bagless vacuum. Beater bar siezed
1. Uing the appropriate sized drift punch, tap out the steel axle rod which passes through the beater drum.
2. Each end cap houses a 608ZZ ball brg.
3. Check each brg for freedom of smooth rotation. Replace both if either is seized.
4. Replace with either 608ZZ (dbl shielded) or 608 2RS (dbl sealed) brgs.
5. Inspect and be prepared to replace the drive belt since it may have been damaged in the seizure event.
Posted on Sep 07, 2009
Vac Belts
  • 701 Answers
SOURCE: How do I change a belt in a 6579 Bissell ?
Here is a link to a site where you can view the manual which has instructions on how to change the belt. You can also get the belts you need here:
PowerForce Manual & Replacement Belts
Posted on Nov 04, 2009
Handle won't catch
Hi Robert! Sounds like the handle release pedal may be broken. You may want to have a Qualified Tech at one of our Authorized Service Centers inspect your vacuum.
Here's a link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 04, 2013 | Bissell 3920 Bagless Upright Vacuum
Tip
I have a Bissell Total Floor vacuum. The handle release pedal broke so now the...
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Nov 08, 2010 | Vacuums
Handle Release Lever/Pedal 203-2347
Hi Chris! I'm sorry; You'll need to contact one of our Authorized Service Centers for assistance.
Here's a quick link to help you locate one in your area:
May 18, 2013 | Bissell Model 3910 Upright Vacuum Cleaner...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 3595 handle release pedal spring(?) missing
Aug 30, 2008 | Bissell 3522 PowerForce Bagged Upright...
How do i take off the handle release pedal on a Bissell model 8990 cleanview bagless sweeper so i can fix it ret1@tampabay rr.com
How do i take off
ret1@tampabayrr.com
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Vacuums Logo
87 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
