DTV Pal: Timer resets to 'no timer set' after 4 - 12 hours. I perform all steps to set the timer; confirm that it's set, and actually, it works on one of two units. On the 2nd unit, i do the same thing and after 3-5 programs have been properly set up, i check 6 hours later and "No timers set" We had a power outage last week, and now BOTH units do the same timer cancel thing.
  • Bobby Koch Sep 19, 2008
    Original post:
    On the 2nd unit, i do the same thing and after 3-5 programs have been properly set up, i check 6 hours later and 'No timers set'
    I have 2 of these units. The left one works fine and keeps the programming.
    The rite one, identical to the left, but hooked to a different VCR LOOSES the programming in 4 - 12 hours.
    I have read and re-read the manual and i am doing the same things on both machines. They are hooked to the same roof antennae.
    They should be performing the same way, but the rite one looses the timer settings.
    In the book, on page 17, it says: Inactivity Standby...turns off...allow(ing) the receiver to perform basic maintenance.
    Both the working and non working machines are set at the 4 hour 'Inactivity Standby' setting.
    Any hope?
    Brigadier General:
  • 6,966 Answers
I was made to understand that there is a firmware glitch on the timer. Other reported issues were:
  • loses about 5 minutes per day;
  • can not manually adjust the clock;
  • constant running of the setup wizard every day to get the correct time;
  • erratic performance of the program guide and event timers for recording.
Options are:
  • claim warranty service/replacements (1-888-638-9912);
  • firmware upgrade, though there is no field/user way to upgrade the firmware and would require an in shop service. reported units with older versions of the firmware (F105 and F205) have multiple problems ;
  • inquire from Dish Network for any over the air updates;
  • try a reset, unplug from the mains for at least an hour.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 19, 2008
    Sergeant:
  • 300 Answers
Simplified Event Timer Explaination.
Event timer
Set a timer to turn your DTVPal on and tuned to the desired channel before your favorite show starts playing.
If your Event Timer is manfunctioning it's time to think about Warrenty or Replacement
Selah.
Posted on Sep 15, 2008
    Master:
  • 763 Answers
Did you try to set it again and did you look on the manual of it? try to configurate it out by using your manual. if your not having trouble in the hardware then its just a settings. hope that helps!
CHARCOIS
I have the UPM ETW 350 user manual. It is easy to follow up to and incl. setting on time BUT setting off time is a mystery. Is there a 1-800 nu. I can call to be waled thru?
http://waterheatertimer.org/UPM-timers-and-manuals.html
This line of timers has mostly disappeared from market... I do not know who is offering tech support for the product.
If you purchased the timer recently, it may be previously used or non-functioning.
The manual is complicated and incomplete ... probably because they have built-in or intuitive steps that display when you program the timer... or they assume you want to fiddle around with their product.
It appears the timer must be wired correctly prior to programming.
http://waterheatertimer.org/How-to-wire-timers.html
- you set the current time first... you toggle through menu choices using arrow keys... go to clock...press set.. toggle to find current day (today) and then press set button... then do the same for hour and minute... pressing set button to confirm each selection.
- to program... you toggle through menu choices using arrow keys... when 1 ON appears on display... press set... select day or days for program 1 on using arrow keys... press set... select hour and minute... and press set after each to confirm selection.
These steps confirm setting for program 1 ON ...the day hour and minute that program 1 turns ON
Each ON program requires OFF program..
Probably the timer automatically displays program 1 OFF as soon as program 1 ON is set... then you follow same steps to select day, hour and minute for program 1 off.
Repeat steps to set up to 20 programs.
Do not touch buttons for period of time, and the timer probably displays current time and is ready to go, but manual is unclear about setting the mode..
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
Gene
Water Heater Timers Save Money
Mar 06, 2015 | UPM Hardware & Accessories
How do i reset my lamp timer on my nec v260
go to menue / reset/clear lamp hours,
all the buttons needed are on the box, push menu & with the cross navigate & with enter confirm selection, exit gets you back at any time, on the nec/support website you can get the np-v series manual
good luck
Oct 30, 2014 | NEC Display NP-V260X Dlp Projector - 3D...
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Intermatic digital lamp timer dt300. I can only get to set it to 24 hour. it does not go to 12 hour when i reset and then hold down the clock button. what am i doing wrong?
There is no repair for defective timer.
The DT300 is sold under at least 3 different brands and product numbers, and each manual shows identical steps for choosing 12H and 24H format.
The manual says to press and hold CLOCK button until display shows 24H. Then press HOUR button to change to 12 hour format.
I am guessing this step cannot be done if timer has programming in memory, so timer has to be reset first by pushing in reset button for a few moments.
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Intermatic Hardware & Accessories
I need instruction manual for TD126 timer
TD126 timer
I'm going to guess at these instructions since they're not posted anywhere yet.
It's a chance I will be wrong, and others can add a comment and refine the answer.
The other option is: you can buy timer and scan your manual into pdf format and post it on your website for free.
Then add a comment with manual web location so we fixyans can sell your manual and manual information to other folks who are wanting a manual to sell to other folks.
Another option: You can pay a fixyan to buy the timer and do the work for you.
My guess is that free is better:
Plug timer into outlet for 1 hour to charge battery.
Remove timer from outlet to program.
Timer appears to be a 24-hour repeat timer with 12 hour am-pm format
There are 5 buttons on face of timer: Reset SET + - Finger
-Press reset button to clear programming.
-Set current time: Push and hold finger button while pressing + and - until current time and am pm display. Or push and hold SET button while pressing + and -.
Program timer:
-Press finger until PROG 1 ON displays
-Press press + and - to set program1 ON Hour.
-Press SET to confirm hour
-Press press + and - to set program1 ON minute.
-Press SET to confirm ON minute
-Press finger until PROG 1 OFF displays
-Press press + and - to set program1 OFF Hour.
-Press press + and - to set program1 OFF minute.
-Press SET to confirm OFF minute
-Press finger until PROG 2 ON displays
-Repeat steps above.
-When programming is finished, push set button.
And you might have to push finger button, or push and hole finger button, and then set button.
-Timer appears to be in AUTO as default mode.
Timer may also have a switch located on side of timer. Move switch to timer if there is a switch.
Some timers also require you push two buttons at same time to enter different modes, or hold one button while pushing other button.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 10, 2011 | Hardware & Accessories
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
I cant figure out how to set it.
http://waterheatertimer.org/pdf/Woods-59203.pdf
The manual has step by step instructions.
Plug timer into wall to recharge battery.
If battery will not charge, the timer is no good.
Press reset to clear memory.
Select am/pm format by holding clock button.
Set current time by holding clock button down while pressing hour, and then minute and then day
To program timer:
Press program button once and program1 ON displays
Press minute button to set program1ON minutes
Press hour to set program1ON hour
Press days to choose the day or group of days for program1 ON
Press program button again and program1 OFF displays
Press minute to set program1OFF minutes
Press hour to set program1 OFF hour
Press days to choose same days for OFF that you chose for ON
Press program button and program2 ON displays
etc.
To exit programming, press clock
A conflict in programming will cause timer not to work as expected
Make a schedule before programming to avoid program conflicts
maximum load 1000 watts
Nov 08, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How do i program the timer?
You did not specify UPM outdoor timer model.
1)ET525C has 7 buttons, and is shaped like a computer mouse, and has a photocell
2)DT420 & ET420 are dusk-to-dawn timers with clear plastic cover
3)DT523 is dusk-to-dawn and shaped like apple phone
4) PT555 is box-type with a door and timer has 6 screw terminals
I'm going to shoot-wild and offer programming for the one shaped like a mouse, the ET525c.
Here is manual
Download manual if you have high-speed, so you can see print larger.
Manual has 10 pages so I can't repeat everything. You will have to read along with your copy of manual.
1) Timer has MODE choices: I will help you program specific on-off times.
2) Setting the clock: Press SET > press Up-Down to choose day of the week ... if today's newspaper says Friday, set timer to Friday
3) Press Set again to confirm day of week
4) Press arrows to set hour. If your watch says 10:30 am, click arrow until 10 am shows
5) Press Set to confirm hour
6) Press arrow to set minutes, until minutes match your watch.
7) Press Set again to confirm everything.
Clock is displayed now
Programming timer:
Timer gives you 20 programs
PROG1 PROG2 etc to 20
Each program needs a DAY it will operate
Each program has ON time, and OFF time
PROG1 ON
PROG1 OFF
Select PROG1 using UP key
Manual page 6 has diagram showing how display looks
Press UP until PROG1 ON shows
Notice: PROG shows in upper right corner, and 1 ON displays to the right of time
This means PROG1 ON
Note: sometimes the instructions say press UP, and sometimes they say press UP or Down ... when in doubt, write out the instructions, and it helps you understand.
Now press Set to begin
Press UP and different days will show. MO for Monday, Weekdays, weekends.
Press Set to confirm days you want PROG1 to turn ON
Press UP or DOWN to set hour you want PROG1 to turn ON
Press UP or DOWN to set minutes you want PROG1 to turn ON
Half way done with PROG1, you need to set PROG1 OFF times
Press UP until PROG1 OFF shows
Look at display, and look at figure page 6 manual
To right of time is number 1 with tiny word OFF, in upper right corner of display is PROG
Press Set to start
Press arrows until day shows (default will flash same days you picked for ON times) Tip: keep the same days!!! or timer will reset ON times for some reason.
Press Set to confirm days timer will turn PROG1 OFF
Press UP and DOWN to set hour for PROG1 OFF
Press UP and DOWN to set minutes for PROG1 OFF
To advance to PROG2, PROG3, PROG4-20, press UP key
To end programing mode, press DOWN
If no keys are touched for 1 minute, timer returns to clock mode
Instructions carry on with more options, if problems persist, take aspirin and post again in the morning.
Oct 04, 2010 | UPM Heavy Duty Outdoor Programmable Timer
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Set time
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
